Results 1 to 10 of 13
Thread: 4 pin Pixel configuration
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Default 4 pin Pixel configuration
    I am about to finish of 8x RGB Pixel based mini trees figure I should wire them the same as the majority of users.
    Is there a standard for the pin connections on Pixels?
    If not what shall we make the DIYC standard?
    MPH can you advise what you recommend?
    Once this is sorted I will add toe the Wiki.
    Check it out here
    7,768
    Default Re: 4 pin Pixel configuration
    My vote would be for the E681 convention (see http://sandevices.com/documents/E681...structions.pdf - page 10 - bottom left) - it supports a reasonable amount of power and has both C and D connectors.
    Brian
    Halloween in San Jose! - FB
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Yep let's make all rectangular / sip connectors the same as Jim's layout.
    How about round waterproof connectors?
    Check it out here
    Nov 2008
    Kernersville, NC
    1,993
    Interestingly enough, the E680 has the clock and data wires swapped from the E681 pins. Of course the pins are spaced different.
    Note also there is the j1sys layout, which uses similar, if not identical connectors, and may have the pin layout different. I haven't checked to see how he does it.
    For the 4 pin circular connectors, it's a toss up on what color wire you get for what pins. Is there a standard?
    Mark
    Kernersville, NC
    www.christmasinapplegate.com
    Worksop UK
    474
    The round 3 pin I got from Ray had brown, blue and green / yellow. As in the UK brown is live and blue neutral and the data wire on the pixels was green it was a no brainer . Brown V+, blue V0 and green and yellow data. I don't know what colours come in the round 4 pin connector.
    2 X E681 running 8 universes of 3001s as a 32s x 42p mega tree or a 96s x 14p matrix hanging from my guttering.
    Canberra, ACT, Australia
    600
    Matt,
    How about using the code already established http://auschristmaslighting.com/wiki...#Round_Moulded
    ultimately the colours may change based on individual orders but could we keep the pinouts consistent to encourage plug and play and interchangeability?
    I'm a little surprised that Jim may have used a differing pinout to j1sys considering he asked to use the same connectors and now does.
    Cheers
    2012:
    Software: LightFactory Personal
    Hardware: J1Sys Pixel controllers . Http://www.j1sys.com
    Lights: 6000+ Pixels and 20k+ LEDs
    Channels: around 20,000 channels
    You know where to find me....
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Default
    Quote Originally Posted by aussiephil View Post
    Matt,
    Cheers
    Phil,
    Perfect. I am happy to reference the offer page. When i look at ACL I didn't find that page, not did i find the material in you 101 manual.
    Sent from my GT-I9100 using Tapatalk 2
    Check it out here
    Matt,
    Cheers
    The 3.5mm euro connectors used on the J1sys boards and on the E681 do have the same pinout.
    The Sandevices E680/E681/E682 Pixel Controllers, part of the PIXEL PROJECT
    www.sandevices.com
    <-email jim at
    Middle Earth
    2,251
    Jim uses the same as Stellascapes, but J1Sys is different.
    On our XLR and PCB connectors, we *always* wire 1- +V, 2-CLK, 3-DATA, 4-GND If we have a 3 wire interface, we just drop pin 2.. The little round connectors are wired differently.. Annoying little bit of history, but given the number of connectors out there, i'm not changing the way we are making them.
    I'd just suggest that its somethignt hat people need to be *very* aware of given that pixels and connectors are coming from multiple places and there is no real standard.
    stellascapes - LED lighting solutions for the Prosumer, Commercial and Entertainment Industries.
    Doing pixels first since 2009 with just another megatree.
    Follow us on Facebook at www.facebook.com/stellascapes
    web: www.stellascapes.com
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Hindsight is a wonderful thing. The purpose of this thread is to document the most commonly used pin outs, not to be critical of development milestones.
    Thank you for your input, but please keep it to the state aim.
    As soon as my Wiki editing rights are sorted I will update the wiki.
    MPH don't suppose you could email me a photo on connectors on the unit. send to matt8baulkolites.com ( you know what to do with the 8)
    Check it out here
