Many of you have MP3 files that you want to sequence to.
HLS requires a WAV file because I have to do things like DSP filtering - etc.
There are some GOOD and BAD MP3 to WAV converters available for free on the Net.
From Version 4P on - I have added "Corrupted WAV File" detection - meaning I check to see if the file contains data I may not be able to process.
When you initially load the song - I will perform the detection process and warn you of the possibility.
If I suggest that you PLAY the audio prior to starting any sequence activity - please do so.
I don't want you to find out you have a WAV file I can't process after you have put in a couple hours of sequence work.
Joe
