Results 11 to 19 of 19
Thread: Multiple sequences at once
    Aug 2007
    Hermitage TN
    45
    Elizabeth City, NC
    429
    Default Re: Multiple sequences at once
    Quote Originally Posted by corytcline View Post
    So when you say another instance of vixen what do you mean? Does that mean open vixen and run one sequence then open vixen again and run Seperate sequence on another com setting?
    Yep!
    3750 + E1.31 Channels (3x E681)
    128 Renard Channels
    sequencing with LightShow Pro 2.5
    640 Pixel Mega Tree w/ RGB Star, RGB Pixel Roofline, 6 x GECE Icicle Arches, 8 x RGB Mini Trees, 2 x Vertical Pixel Poles, 10 x FAST + more
    Dec 2010
    oklahoma
    675
    Default
    Thanks jaywalk that sounds easy enough although last year by newbi mistake I had opened vixen twice and it was causing issues, could that have been because both instances of vixen were programmed to the same com setting?
    not so new but still learning!
    Dec 2010
    oklahoma
    675
    Default
    Will opening two instances on Seperate con ports eliminate the need for a second sound card?
    Nov 2008
    Kernersville, NC
    1,995
    I think you still need the second sound card, unless you're just planning to play sound in the tunnel and no other sound anywhere else.
    Mark
    Kernersville, NC
    www.christmasinapplegate.com
    Apple Valley, MN
    3,195
    Do you need to have stereo outside? You could have totally different sound on each channel.
    As far as sharing the sound card… it depends. If your sound card shows multiple drivers, you might be able to use different drivers for each instance of Vixen. I’ve had soundcards that I could do this with. Vixen really is just showing you the driver that it finds; see if there is more than one.
    A mediocre person tells. A good person explains. A superior person demonstrates. A great person inspires others to see for themselves.
    Click here to show/hide DIYC Links ...
    Nov 2010
    Placerville, CA
    1,811
    We're can I get a USB sound card
    Check here:
    http://s.dx.com/search/usb+sound
    As low as $2.10 shipped. I have that $2.10 one and it works nice (in general) for sound output...
    "Beam me up Scotty, there are only limited pockets of intelligent life on this planet!!"
    Aug 2007
    Hermitage TN
    45
    Mine is running my background sequence on Sound card (USB) 1 and the coffin sequence is running on the other Sound card (USB). Both are looped and playing over and over. I did not need another instance of Vixen. In fact I just loaded a third sequence with lights and sound and all three are running just fine. Do remember I am using a Grinch as my controller. My pc is a Dell 170 (2.8 gig with only 256 MB of ram) with XP and service Pack 3.
  9. #19
    Dec 2010
    oklahoma
    675
    Default
    I figured out an easy way
    I'll just run the main show off one controller and CPU then run the tunnel off of a laptop and Seperate controller. Gould have bought of that sooner sometimes I have to laugh at myself.
