Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: My Afternoon playing with HLS
    Huntsville, AL
    3,644
    Default Re: My Afternoon playing with HLS
    Henedce - Nice video.
    As I was watching it - multiple things came to mind that (thanks to your video) that are now changes/capabilities in version 4K.
    1. Change in current behavior - I had used the GREEN (End Time Tic Marker) as an EXCLUSIVE marker. You presented it as INCLUSIVE - so 4K now make it inclusive is deciding the right hand boundary of Pixel Plane operations.
    2. You laid out 800+ RGB channels and dropped down Level effects down - all White. If you wanted to drop another set but with a different color - you would have to change the color associated with the RGB channel - one-by-one. That would be a royal pain in the A... Version 4K - use the selection box to identify a group of channels - and change the color associated with those channels all at once. This does NOT change the color associated with any effect already established - only the color of effect yet to be created.
    3. I took#2 a bit further - you drop a bunch of effects down and there all white (you forgot to change the CHANNEL RGB color or it is the result of a copy/paste operation) - you want to change the color. You can use the Over Effect as you did ----- or now in 4K --- you can select a group of RGB effects and change the color of them all at the same time. This would reduce the work you did and would also cover the situation where a group of effects were copied and pasted and the new set needed a different color.
    Again - all new capabilities in version 4K or later.
    Enjoy.
    Joe
    Eagan, Mn.
    4,073
    Hi Joe, I suggest you and a link to your download site to your signature. So when your comments anywhere on the forum tickle someones
    interest they can check out your software.
    Brian
    6,219
    +1 I thought you use to have the link in your sig .
    Brian
    Huntsville, AL
    3,644
    Test to see if my signature now contains the link - thanks for the suggestion.
    Joe
    2,192
    Signature link works just fine ... went to the site and downloaded the manual ...
    \dmc
    ________________________
    Dec 2008
    Bairnsdale, Victoria , Australia
    261
    Joe,
    Yet another feather in your HLS cap.
    Just had a quick play and with the couple of improvements to color management, you have made sequencing even easier.
    Time to get serious about 2012 sequencing.
    2012 Plans
    1 [URL="http://www.youtube.com/watch?v=ve3WkB5TX5U&list=UUbcH2uH27u4rBn63opFisvQ&index=8&feature=plcp"]Pixel Megatree[/URL] (Finished)
    20 x [URL="http://www.youtube.com/watch?v=5K3xghO4els&list=UUbcH2uH27u4rBn63opFisvQ&index=1&feature=plcp"]3D Mini Trees[/URL]
    40 x [URL="http://www.youtube.com/watch?v=00WYHIu0s6E&list=UUbcH2uH27u4rBn63opFisvQ&index=1&feature=plcp"]Mini Roof Stars[/URL] (Finished)
    [URL="http://www.youtube.com/watch?v=475x10tQ4pI&list=UUbcH2uH27u4rBn63opFisvQ&index=10&feature=plcp"]Columns[/URL] (Qty to be decided)
    Pixels Pixels Pixels
    2011
    [URL="http://www.youtube.com/watch?v=uSAgi4SZxp8"]3 x RGB arches[/URL]
    6 x [URL="http://www.youtube.com/watch?v=z4dOhYaGhZM&feature=channel_video_title"]RGB Window Display Trees[/URL]
    2 x [URL="http://www.youtube.com/watch?v=b1ZWdmwvCAk&feature=channel_video_title"]RGB Window Display Bells[/URL]
    6 x [URL="http://www.youtube.com/watch?v=UTuSFFVHYHg"]RGb Window stars[/URL]
    5 X [URL="http://www.youtube.com/watch?v=BMOEEZUSY4s"]Mini arches RGB[/URL]
    [URL="http://www.youtube.com/watch?v=2WQYu6ylfhE&feature=related"]1 x RGB Bethlehem Star[/URL]
    14metres of [URL="http://www.youtube.com/watch?v=XNcPZfj1fWE&feature=mfu_in_order&list=UL"]Eave Lights[/URL]
