The reason for isolation can be either A) to eliminate excessive ground loop currents (via the common reference wire) in systems spanning larger areas, B) to protect other segments from damage due to excessive voltages getting into one segment or C) both.
As for the diodes isolating the two sections, I don't see how that can be true. A quick bit of drawing shows that a large reverse polarity (or AC) spike onto the DC side of one bridge will first burn one or more of the diodes, then more than likely kill the second bridge. How much damage to the transformer secondary and DC side of the other bridge will depend on the surge. I'm happy to be proven wrong of course, but I don't think I am.
David...
this is one of the diagrams i was basing my original circuit from http://dl.dropbox.com/u/48217835/dmx...20isulated.pdf
ive got my circuit running better now, just finishing up on bits.
2012 Checklist:
7x mini floods
2 RGB 9Ch Led Leaping Arch - 630Leds, 9 channels per colour - 27ch's each
Mega Tree 5m - 14x r g b w leds - 54ch's
10x RGB CoroStars - 6 RGB 5050 Leds in each - 3ch
1x RGB Merry Christmas Sign - 42ch's
2x 3section RGB Coro VU Meters - 27ch's each
RGB Led Mega Star - 24ch's, 3ch each point of star
10x Ledancer tubes
150x ACL Led Strobes
1x RGB Coroflake
http://www.youtube.com/watch?v=bH7gDBDrFok
At this point I think that you're right, and that I was writing nonsense before. I think that the 'isolation' between the two sections is limited to two diode forward-drops plus the breakdown voltage of the regulator (or filter cap, whichever is smaller). Once that voltage is exceeded largely uncontrolled currents will start to flow, and various components will be damaged. If I'm right, the isolation between the two sides would be well under 100V, possibly under 50V, which is way too small.
Sales puffery. It's a repeater, not an isolator. Denny, it won't do what you're wanting to do. That 3-in-1 device will, though. It has isolated power supplies and opto-isolators for each section. I'd do it with RJ-45's, though, for your/my purposes. You could be by with doing just one isolator, rather than 3, if your universes don't require a lot of controllers.
Jack,
Yes, I was being somewhat sarcastic in my question - it's a repeater, not an isolator.
I'm thinking that something else is needed - both a RS485 output from the E681 and then an isolation device to protect the output stage.
