Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: HLS - Convert Vixen sequence into HLS - Collapse your 3 pixel channels into 1 RGB
    Aug 2011
    Las vegas NV
    307
    Default Re: HLS - Convert Vixen sequence into HLS - Collapse your 3 pixel channels into 1 RGB
    i have issue when doing the import from fixen file it wont show up in raw channels ( note i have about 4400 total channels with pixels Would i need to do anything different based on my files) Ohhh and i did do a flat file
    Aug 2011
    Las vegas NV
    307
    Quote Originally Posted by ritztech View Post
    Wow first time in 20 different methods doing the same thing it finally worked and converted 4400 channels note all my files are 25ms in vix so i saved it to 50ms But im not sure if that was the failure but i did that and redid everything exact after the change with a new filename and the 2nd time with the new flat it worked
    6,946
    Welcome to the HLS Sequencing Madness
    Good to hear you got if figured out .
