Great post Joe, will save people some time.
Al
If you are interested in Converting your Vixen sequence into HLS - its easy - it may take some time.
Step 1. Load your song.
Step 2. Under "File" menu - select "Import a Vixen File".
It's best to use a flattened Vixen file. If you don't have it, HLS will prompt you for a Profile.
HLS will then load your Vixen sequence and convert as many of Vixen's single tic effects into HLS primitives as it can.
When done - I suggest pressing the SAVE button.
Step 3. If your sequenced contained channels for "Pixels" - I suggest your convert those three channels into HLS RGB channels at this time.
It can dramatically reduce your channel count in the editor.
Under the "Manage Channel" menu - select "Auto Convert Channels to RGB".
The process consists of you placing on a single line - the three channels that are to be converted. Easy but can be tedious if you have a lot of pixels.
I suggest you "SAVE" your RGB conversion selections as it will build a conversion file so that the next Vixen Sequence you convert - all you do is point me to the conversion matrix - and I do the rest.
Step 4. Once you have converted your pixel channels (only if you had some) - create a LIBRARY and save the Sequence LAYOUT in the Library.
That way - when you wish to develop a sequence totally with HLS - you can load your LAYOUT from the Library and all your channels are there for you.
Enjoy.
Joe
Al
Wholly Cow batman! you are makin it simple. I hope to try this tonight
Hi Joe - I tried a Vixen 2.1 import tonight with some odd results. I flattened the sequence OK and imported it into HLS - seemed to work fine - however...
1) There is no sequence information shown on the display at all - completely blank both on left and main pane
2) Apparently the original Vixen adjustable preview data does not import? (or is it related to above?) - if not could this be done somehow?
3) I attempted to convert my pixel setup from 3 channels to a single RGB channels. I then renumbered the channels which prompts for a shutdown. When I do this, I get a dialog box saying that HLS stopped working and "Close the program". I click this, and HLS quits ok - not sure if this is normal
4) If you place a channel into one of the R, G, B slots it creates an RGB name - all good - but if I say 'no' I didn't want that one and right-click to undo that, the RGB channel naming stays there which is a little confusing. I might suggest if the last R, G, or B channel is removed from the RGB table that the RGB name be deleted as well.
Anyway - still playing with it - I am using the latest "4A" version.
edit - one other thing - if you move a R/G/B channel onto an existing one, the previous one is gone and can't be recovered...
[/SIZE]
[/COLOR][/I]
OK - running 4C now - the dialog box on restart is gone now - also the deletion of the RGB name with no channels is fixed - tx!
One thing that I saw on 4A as well is when you go to the RGB converter and click in any RGB name cell it scrolls over and the channel info on the left scrolls off and for the life of me I can't figure out how to get it back.
I freely admit that have not gone through all the videos and documentation quite yet so I'll do that before posting more.
[/SIZE]
[/COLOR][/I]
Brian:
When you click a Channel Name in the first column - there is no scrolling.
I turn the cell YELLOW in color to identify which cell has been selected selected for placement in RGB conversion.
You MUST then place that channel in one of the RGB cells - even if you made a mistake.
If you want it to go back - simply Right Click on the RGB cell and it returns it to the channel column.
Joe
Joe,
I just created an automatic RGB mapping of one of my imported vixen sequences. I want to only generate a preview once but I also want to apply the RGB conversion to all the files. Should we create the preview before the rgb conversion or after? If the answer is before then how does the conversion effect the preview? If After, how do I get the new conversion and previews into the other files. Would I need to run the RGB conversion on each file OR can I just import the new Profile that already contains the conversion?
What is the correct sequence?
Michael
Gotham Beat Productions LLC
Convert Vixen sequence.
Use your RGB conversion to automate the RGB conversion.
First time completed - make Preview and Save layout to Library.
As long as you do not change the name of the channels on your other Vexion files --- the RGB conversion and Preview will match.
Hope that helps.
Joe
Thanks Joe. so after I make the first conversion and preview, the other vixen conversions only require loading the profile and not re-doing an rgb conversion. Do I have that correct?
Michael
