Results 1 to 10 of 13
Thread: Would this Antenna work with an FM02?
    Royersford, PA (Philly)
    1,230
    Default Would this Antenna work with an FM02?
    I've used it with great results for 3 years with my FM25 (1/2 mile, antenna pinned to the 4x10 that covers the steel I beam in the basement (+10' above road grade), moving to an FM02 this year so I can add RDS and cause it's always cool to "build your own!"
    I know the FM02 has an SMC connection, and most use BNC, and from what I can find, the only way to go from SMC to F is via BNC, so I know I have those issues to work with...
    8,023
    Default Re: Would this Antenna work with an FM02?
    Well, if it worked with your FM25, it very likely would work with the FM02 -- sounds like all you have to do is work out the connections...
    dirknerkle
    1,230
    ok, thanks! Just read the the FM02 is very sensitive when it came to antennas, to the point you can burn it out, so I wanted to be sure!
    1,500
    Quote Originally Posted by pmcpa View Post
    As with any radio transmitter, if you power up an FM02 without an antenna, you can burn it out. Ramsey, EDM, VASTELEC, one of your own creation -- there needs to be a load on the antenna connector or you will release the magic smoke. I don't believe the FM02 is any more or less sensitive than any other transmitter.
    \dmc
    ________________________
    1,230
    Makes Sense.... Thanks for the re-assurance!
    St.Louis mo
    685
    I thought it was SMA on the fm02
    1,230
    yea, I think your right.... switched a letter
    St.Louis mo
    685
    Ok just didn't want you to buy the wrong connector/adaptor since the is a smc type.
    Nov 2010
    Placerville, CA
    1,809
    Wait - Huh? SMA is a smc type?? What?!?!? <confused>
    St.Louis mo
    685
    Not on the fm02 but in general there is a SMA and smc type rf connector
