Results 31 to 33 of 33
Thread: Nutcracker Gif to Pixel Tree
  1. #31
    Littleton, Colorado
    864
    Default Re: Nutcracker Gif to Pixel Tree
    Sean, The first two, the spiral and the meteor the bottom shows the front half of the tree (arced down) but the flag is showing the back half of the tree (arced up at the bottom). Seems like they should be the same. Maybe you already know about it but just in case you didn't notice here ya go.
    Brian
    Thanks Brian, the "set viepoint" command for gnuplot had an error after i did the above fixes. I have corrected it. People wont know what you are referring to since when i made the change, it automatically corrected the above image.
    The bug (now fixed) was that gif files were displayed right to left instead of left to right. It was obvious on the flag since the canton portion was on the right side.
    fixed now
    Sean
    Highlands Ranch, CO
    Nutcracker RGB Sequence Builder http://nutcracker123.com/nutcracker
    Build your own 9' Nutcracker http://meighan.net/build_your_own_nutcrackers
  2. #32
    Dec 2008
    Bairnsdale, Victoria , Australia
    261
    Too tired tonight to wait for the you tube video to upload, so going to post now anyway.
    Sean's suggestion to change my tree a 24 x 84 model and change the Nutcracker files to 180 degree vies made a significant improvement.
    One note the flag now displays backwards. The rest of the video is the same effects as earlier, the only difference being the output model and view has been changed to 180 degree.
    Enjoy, when its available that is
    2012 Plans
    1 Pixel Megatree (Finished)
    20 x 3D Mini Trees
    40 x Mini Roof Stars (Finished)
    Columns (Qty to be decided)
    Pixels Pixels Pixels
    2011
    3 x RGB arches
    6 x RGB Window Display Trees
    2 x RGB Window Display Bells
    6 x RGb Window stars
    5 X Mini arches RGB
    1 x RGB Bethlehem Star
    14metres of Eave Lights
  3. #33
    Littleton, Colorado
    864
    Quote Originally Posted by Henedce View Post
    looks nice!
    i am aware of the flag being backwards. i have to make one change to detect if your using a 2d matrix or a 3d tree. It turns out i need to change the viewpoint .
    Sean
    Highlands Ranch, CO
