Re: Nutcracker Gif to Pixel Tree
Originally Posted by
smeighan
Following up on last thread. Using a 12x84 folded string on 360 degrees (24 strands x 42 pixels) versus a 24x84 folded tree (48 strands x 42 pixels) with a 180 degree window.
Here is the gif you have when u use a 12x84 string, folded into 24x42 and draw it with a 360 degree window.
here is the same as a 24x84 folded target which gives spacing of 48x42 with a 180 degree window. You'll notice the gif now matches the video much better.
Here is a comparison of the meteor4:
and finally, the animated gif effect. Looking into this, i see I somehow forgot the window_degrees prompt on this effect (Bug!). So when I picked 180 degrees with the effect, the effect was shifted 90 degrees (Bug!). I have fixed both of these.
I still need to add autoscaling to the gif effect (somethign that is on my large to do list). But here is the australia flag on
48x42 360 degree vs 24x42 180 degree. The animated gif is getting clearer.
Sean, The first two, the spiral and the meteor the bottom shows the front half of the tree (arced down) but the flag is showing the back half of the tree (arced up at the bottom). Seems like they should be the same. Maybe you already know about it but just in case you didn't notice here ya go.
Brian
