Results 1 to 5 of 5
Thread: Water displays
    Default Water displays
    Has anyone used Vixen to control lights and fountains in a water display.
    I started with just doing a single spray in the backyard pond,
    now I'm getting all Bellagio.
    Jumping water jets, lights, agghhhh.
    Thought of using the 12 or 24VDC Renard controllers.
    I thought there was a thread here a while ago.
    Found this
    http://doityourselfchristmas.com/for...ighlight=water
    but wondered if any diyc'ers have done anything.
    Sep 2011
    Wyoming
    23
    Default Re: Water displays
    I built a couple of laminar fountains a while ago using RGB LEDs but I wasn't exposed to Vixen at the time.
    Here is an amazing website for laminar fountain design: http://laminar.forumotion.com/
    And here's a link of some early pictures of mine (no pics post lighting setup though): http://laminar.forumotion.com/t162-i...laminar-nozzle
    Last Project: Laminar Fountain
    Current Project: LightWeb ethernet lighting controller
    Next Project: Private Cyber-clone army
    Continuous Project: Convincing my wife to let me keep spending $$ on projects
    Thanks, the laminar fountain is part of the project.
    For now, I'm looking to use lawn sprinkler valves to turn on different sprayers.
    To start, probably eight, plus 8 lights to fill a Ren16.
    Then onto 24 etc.
    Just south of Portland Oregon
    794
    My Wife, in NO uncertain terms forbade me to dig a pool and animate it with water.
    I for one think your idea sounds like a ton of fun and very cool. I see no reason why you couldn't use a RENLSD (wired or wireless) or even a mixture of DC and AC SSRs with a wireless simple32 or whatever floats your boat - so to speak.
    We have a small pond in the yard, and just wanted to 'animate' it a bit with a fountain.
    For now, it's just a 1/2 hp sump pump, a pvc pipe with holes cut into the cap for the spray pattern,
    and a few low-voltage landscaping floodlights.
    But I can see a pvc pipe arrangement with 8 valves and (at first) 8 light channels.
    Doing this all with 12 or 24 volts (except the pump) keeps the power safe.
