Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: HLS supports large Pixel Count Effects - Nutcracker example
    Key West, FL
    1,493
    Default HLS supports large Pixel Count Effects - Nutcracker example
    HLS can now sequence large pixel count effects with little impact on the Channels shown in the Editor.
    Below is a video on how I loaded a 180 pixel Nutcracker effect into HLS.
    Sean created a Megatree using 180 pixels and that is 5 secs long.
    In real terms - that's 540 channels of data.
    In HLS - that effect is displayed in the Editor as a single channel.
    Enjoy.
    Joe
    Tustin, CA
    1,134
    Default Re: HLS supports large Pixel Count Effects - Nutcracker example
    So can this handle a 1,000 or 2,000 pixels in a plane?
    Key West, FL
    1,493
    We will know when it happens.
    It is designed for 10,000 channels.
    Joe
    I real like how you have compressed the effect on to a single row in HLS, imho this is one of the issues with going large rgb pixel counts, you don't want all that detail in your sequencer unless you are going to individually change some of the values manually. it should be good enough that you can add a spiral nutcracker effect to your sequence and put it on the time line.
    With the tools such as HLS, Lightfactory, Madrix and nutcracker I can see how our 'hobby' can grow into something special.
    Key West, FL
    1,493
    Quote Originally Posted by neilric99 View Post
    I don't allow you to edit the "pixels" in the editor (that is what tools like Nutcracker are for) - so if you can't edit them - why have them clutter up the channels you can edit.
    The channels are still there - but only when required - as in actually talking to the hardware to blink lights.
    If you want to change a pixel or two manually - edit the Nutcracker HLS export file - its really simple.
    I hope this helps all those who would like to use Nutcracker in their shows.
    Joe
    Dec 2008
    Bairnsdale, Victoria , Australia
    261
    I have outputted 1008 pixels (6 universes) without any problems outside some internal issues, which Im sure will be addressed soon .
    The more i play with this the more I like it. Not sure I will end up using it quite the way Joe envisioned but I have thoughts in place to adapt what he has done to my own way of thinking.
    2012 Plans
    1 Pixel Megatree (Finished)
    20 x 3D Mini Trees
    40 x Mini Roof Stars (Finished)
    Columns (Qty to be decided)
    Pixels Pixels Pixels
    2011
    3 x RGB arches
    6 x RGB Window Display Trees
    2 x RGB Window Display Bells
    6 x RGb Window stars
    5 X Mini arches RGB
    1 x RGB Bethlehem Star
    14metres of Eave Lights
    May 2010
    ottawa , ontario, Canada
    761
    Quote Originally Posted by Henedce View Post
    hey bud how many chanel is your colum ?? they look like you used dum rgb for them ??? and how tall are they ?
    thanks
    Dec 2008
    261
    thanks
    I guessing you mean this one
    It was originally made with dumb modules but I have since discovered pixels . The final product will be made with something like
    http://www.aliexpress.com/fm-store/7...vel-DC12V.html
    Not quite sure yet whether I use them or just 12v strip.My time for the last 2 - 3 months has been spent getting my pixel tree up and running. And then playing with real outputs to it.
    The column in the video is around 10 ft or 3 meters high. The original in the video is using 27 channels of dumb modules .
    2012 Plans
    20 x 3D Mini Trees
    2011
    3 x RGB arches
    5 X Mini arches RGB
    hello
    been trying to load a nutcracker file to a HLS show. After the nutcracker effect build I save it to my PC. I have now downloaded two different files HLSNC and text file.
    Everything is built my HLS show, go to drop my nutcracker file onto the show and get an error"unable to open the nutcracker file". Used the tutorial in the first part of this thread with no joy.
    What file should I be using, HLSNC or text file?
    Key West, FL
    1,493
    File extension HLSNC is just a way of identifing the file as a HLS NutCracker file.
    It has no other purpose.
    When HLS asks you for the file name - select your NutCracker file - whatever name/extension you used.
    Joe
    Link to my DownLoad Site: http://www.joehinkle.com/HLS
