Results 1 to 6 of 6
Thread: Help with DMX please
    Default Help with DMX please
    OK so I have an avd dc24 and a RPM usb to dmx dongle. They should work ok together correct?
    https://www.audiovisualdevices.com.a...productid=DC24
    I installed the drivers for the dongle successfullyand the LED flashes when just connected to the PC and Vixen is not running. problem or am i ok?
    What is the proper pin arrangment to connect the dongle to the controller?
    Thanks for any help
    Brisbane - Australia
    769
    Default Re: Help with DMX please
    Hi,
    There is a wiki page for the DC24 here. The RJ45 pinout for the DMX input is here.
    David...
    1,499
    Well, that's a new one on me ... had never heard of these guys before.
    Anyway, the RPM dongle is going to send out DMX on Pins 1 and 2 of the RJ45. The basic question is, "Where does the dc24 receive DMX?"
    The phrase "Light-o-Rama" is used on this device's sales page; LOR uses Pins 5 and 6 (I believe ... or is it Pins 4 and 5?) for DMX.
    You'll need to ask the AVD guys where their DMX input is on those RJ45 connectors. If it is anywhere but Pins 1 and 2, you'll need to build a conversion cable.
    \dmc
    ________________________
    769
    The DC24 uses the standard ESTA (Plasa) RJ45 pinout.
    1: D+
    2: D-
    7+8: Common
    David...
    Thank you both for your help.
    -bump-
