Re: Jumbo Tree Ornaments
Originally Posted by
dirknerkle
Direct from the 48LSD. Since it's only RGB and I'm not using the Ren48 breakout boards, I'm actually wasting one channel (the W one) out of each RJ45 jack, too, and only using 3 of each set of RJ45 channels. So while technically you can get 16 sets of RGB channels out of a 48LSD for 16 jumbo ornaments, I'm just putting one jumbo ornament on each RJ45 jack, so I'll only get 12 ornaments out of the controller. I'm wayyyyyy too lazy to rip the controller apart or build a dozen short cat5 cables to connect to a breakout board...
Instead, and if I get energetic, I may put 6 DIGWDF HeadBlinkers inside a CG1000 box for 48 channels along with a 12v power supply and solder the cat5 wires into the holes where headers would normally go. This would give me a small, wireless (4"x 6") 48-channel LED driver for 16 jumbo ornaments.
You could run the cat5 from the 48LSD out to the tree, then the breakout board in a TA200 with outputs to the ornaments in the tree. Save some cat5 runs and get more ornaments. Win-Win and no baby cat5 cables.
Brian
