I finally got 6 arches, 32 pixels each, built using my GECE's. I got an idea over the weekend to put them across the front of my porch using them for ambient lighting and a good way to test them out. Last night I had them all hooked up to my E681, ELOR and was using a few different sequences with S3. All my tests were working great, fading between colors, changing colors. My problem started with chases. If i did a chase with a fill and then a chase to off, the chase turning the lights on worked fine, but the chase to turn the lights off would leave about every 5th pixel still on. Didnt matter what color I used, it happened every time. If they turned on fast and off slow, it would still leave about every 5th pixel on. If I did a chase to turn them on and all off at the same time, it worked ok, it only screws up when the chase goes backwards.
Anyway, I was hoping someone who has a E681, ELOR and hopefully GECE pixels although I cant imagine its a pixel problem would run the same test for me and see what there results were. This makes no sense to me. Today I disconnected all but the first 32 pixels and it did the same thing. I dont think its a power supply probelm as all the lights when turned on turn a very bright white.
If anyone has any ideas it would be greatly appriciated. Thanks.
