Thread: Using FETS for polarity protection and soft start up..
    Nov 2007
    Middle Earth
    2,251
    Default Using FETS for polarity protection and soft start up..
    I've recently been working on a project where ensuring that the Power input to it was *always* correct. Given the cabling setup, it could be possible for an inadvertent crossover to be made, and the results would be quite catastrophic.. The exact circuit doesn't really matter, but it operates on DC with about 4A flowing.. THe system is housed in a waterproof sealed box, so keeping it cool is very important as well.
    So, polarity protection is simple right, just put a diode in series? Lets have a think about that.
    A silicone diode with 4A passing through it, is going to get pretty hot.. its going to drop .7V @ 4A, thats 2.8W! In a small box thats going to get quite hot.. Not an option..
    So, what options could we use instead?
    Worksop UK
    474
    Default Re: Using FETS for polarity protection and soft start up..
    Why not fuse the input and use a diode in parallel in the reverse direction - if the polarity is reversed the diode will conduct above 0.7 volts and blow the fuse. Not very flash but it's cheap and will save the other stuff.
    2 X E681 running 8 universes of 3001s as a 32s x 42p mega tree or a 96s x 14p matrix hanging from my guttering.
    Key West, FL
    1,493
    Removed so training can continue.
    How can I remove the attachment?
    Joe
    Key West, FL
    1,493
    Quote Originally Posted by mrpackethead View Post
    I'm sorry. I replied as if you were looking for a solution. Re-reading your thread - it appears you were starting a "teaching" thread;
    Joe
