Results 11 to 20 of 22
Thread: Nutcracker --> Arduino?
    Illinois
    180
    Default Re: Nutcracker --> Arduino?
    No, I don't need the string number. Just the value bytes in a certain order and I'll figure out what data goes where.
    Say I've got 12 channels.
    The first event for a spiral is to have channel 1, 2, and 3 on and all of the others off. The first string will look like this
    88 AA FF 00 00 00 00 00 00 00 00 00
    The second event has 4, 5, and 6 on and all others off
    00 00 00 88 AA FF 00 00 00 00 00 00
    It may also be worth while to have the sequence length (2000 milliseconds), event period (50 milliseconds) and number of channels in the file. That way it does not need to be entered manually. ASCII characters are ok, maybe separated by spaces.
    So the beginning of this file would look like this:
    2000 50 12 88 AA FF 00 00 00 00 00 00 00 00 00 00 00 00 88 AA FF 00 00 00 00 00 00 ....
    - Jon Proietti
    Indiana, USA
    213
    Quote Originally Posted by Jonpro03 View Post
    Are you talking about "12 pixels" or "12 strings of 'dumb' RGB lights"? If you're talking about twelve pixels, then I don't think your suggested format is very scalable. If I'm working with 100 or 1000 pixels, that becomes one huge line of code/data. Is that manageable?
    Or am I not thinking enough like a microprocessor?
    Illinois
    180
    I am worried about the capability of the processor. I realize that a realistic channel count is way over 1000. With an event period of 50 milliseconds, the Arduino will be expected to read in 1KB+ of data and move it out within that time period.
    Perhaps it may be beneficial to address the bytes so we can prevent the Arduino from reading in a bunch of off channels, and just have it assume that all channels are off unless a byte is addressed to that location. It would decrease file size and read times.
    I need to read into the pixel library a bit to find out what exactly is needed from the Arduino.
    What library does everyone use?
    Is it the Ladyada one or the GE one?
    Or should I plan on both haha!
    - Jon Proietti
    Littleton, Colorado
    871
    Before i produce a file maybe that concept should be proven.
    A 3 minute song using a 50ms frame rate on a mdeium sized tree (16x50)
    180 secs x 20 frames/sec * (16x50) pixels * 3 channels per pixel = 8.6mbytes of binary data = 48kbytes/sec
    a larger tree (48x64) , which one nutcracker user has, = 33.2mbytes for the 3 minute song = 184K/sec
    Does the arduino support a sd card? I was thinking we could load teh card from a pc and then plug it in after it has a show.
    It seems to be scalable for the future, you would have something like this
    for each frame
    for each string
    for each pixel
    output r,g,b
    somewhere in here you will span dmx universes
    Sean
    Highlands Ranch, CO
    Nutcracker RGB Sequence Builder http://nutcracker123.com/nutcracker
    Build your own 9' Nutcracker http://meighan.net/build_your_own_nutcrackers
    Illinois
    180
    There's a reply in this thread http://arduino.cc/forum/index.php?topic=66241.0 in which the author of the SD library says that we can expect read time's of 250KB/sec on an Arduino. So we know that the limiting factor will not be the read speed of the SD card.
    In order to update a single pixel, both the adafruit and the GE strings require the entire string to be updated. I think it may defeat the purpose of addressing bytes.
    Thoughts?
    - Jon Proietti
    Littleton, Colorado
    871
    Thoughts?
    maybe for scaling we could divide the pile of data for a song in two and have two arduino's each driving half of the tree. Can two of them be kept in sync to within say 25ms?
    Sean
    Highlands Ranch, CO
    Illinois
    180
    Arduino's can communicate with each other, using I2C I think.
    What I'd like to do is get some pixel strings, hard code some channels on the SD, and push the limits to see where we stand. I'd also like to know what everyone is using on their trees/etc...
    Sadly, it'll be a while before I can spend some money on blinky/flashy
    - Jon Proietti
    Wisconsin
    162
    I have an Arduino and the Ethernet shield (has SD card slot) ; also some WS2801 strings. I would love to try this out for you.
    Illinois
    180
    Quote Originally Posted by bigredsoftware View Post
    How many strings do you have? I'll throw something together.
    - Jon Proietti
    Wisconsin
    162
    Is this kind of what we want to do?
    http://www.ebay.com/itm/WS2801-SD-ca...item2570073048
