Results 1 to 10 of 17
Thread: Twinkle Twinkle Little Star
    Dec 2008
    Bairnsdale, Victoria , Australia
    261
    Default Twinkle Twinkle Little Star
    My roof was a bit bare last year so I thought I might make some Coro stars .
    These are approx 8" across and the plan is to make 40 of them. Each one contains 3 LPD6803 pixels powered by J1sys's P12R pixel controller.
    Will see how long You tube leave it up for.
    2012 Plans
    1 Pixel Megatree (Finished)
    20 x 3D Mini Trees
    40 x Mini Roof Stars (Finished)
    Columns (Qty to be decided)
    Pixels Pixels Pixels
    2011
    3 x RGB arches
    6 x RGB Window Display Trees
    2 x RGB Window Display Bells
    6 x RGb Window stars
    5 X Mini arches RGB
    1 x RGB Bethlehem Star
    14metres of Eave Lights
    Default Re: Twinkle Twinkle Little Star
    Great job!
    Hamilton, OH
    235
    Love them! In the video they appear very small and the coro looks about an inch thick. Would you mind taking a picture of one of the stars in daylight and maybe next to a common object to gauge the size?
    Tustin, CA
    1,134
    Default
    Looks really nice. Which type of pixel did you use? Link to Ray's would be great.
    John
    Dec 2008
    261
    Yes they are small but that is what I wanted so I can spread 40 across my roof. They are actually just over 2 inches thick.
    Link for Rays is http://www.aliexpress.com/fm-store/7...-a-string.html
    I only used these as I have 6 strings that were originally destined for my pixel tree before I rehashed it. Although the did turn out well. I plan to extend the cables between each one to 24" - 36" once I get the plugs from Ray .
    2012 Plans
    20 x 3D Mini Trees
    2011
    3 x RGB arches
    5 X Mini arches RGB
    Dec 2008
    261
    40 Coro stars sounds so easy when you say it quickly.
    3 weeks later all 40 are complete. You just don't realize how much time is involved in cutting up and plugging 120 pixels into groups of 3 . Let alone cutting out 80 stars , 40 side pieces and 40 supports. Glue all that together, another 3 - 4 hours to get the layout right and here they are ready to plug into a controller hopefully tomorrow and run some tests.
    2012 Plans
    20 x 3D Mini Trees
    2011
    3 x RGB arches
    5 X Mini arches RGB
    Nov 2008
    Kernersville, NC
    1,995
    Looks quite nice.
    yes, the work to build stars does add up. I did 5-6 of them, about twice the size of yours, last fall using RGB modules. They didn't get mounted last year in time for the show, but this year will be out on the house!
    What kind of plugs/connectors did you use to connect them together?
    Mark
    Kernersville, NC
    www.christmasinapplegate.com
    May 2012
    Vancouver, Washington
    55
    I am looking at getting a supplier to build something similar using a hard plastic housing. The sides would be a black plastic and the cover would be a milky white cover. Inside would be a WS2811 (6) 5050 LED module in the middle of the casing. Each star would be about 8 inches across and have a set of 4 wire plugs to connect. One cable would go out each side to allow them to be connected together.
    The case by itself will be $5 with a WS2811 module and pigtails I think would be another $5 and shippnig for the components...
    Would having all the labor be done be worth $15 a star?
    I have the case already I can post a pic or two tonight...
    Nov 2008
    Kernersville, NC
    1,995
    Sounds interesting. What kind of hard plastic? UV resistance? The beauty of coro is that it weathers fairly well, or can be replaced if necessary.
    But the price @ $5 for the case seems quite reasonable.
    Mark
    Kernersville, NC
    May 2012
    55
    It appears to be a Polycarbonate. I am requesting more info from the manufacturer.
    I found this pic, it is not a great pic but would give you the idea... One thing I like about this case, because the sides are black, the visible light really gets defined in the star pattern. Where the coro stars bleed light on the sides unless you use black coro or paint them.
    -Daryl
