Results 11 to 20 of 24
Thread: Lack of communication to the E681
    Oceanside, CA
    2,363
    Default Re: Lack of communication to the E681
    Quote Originally Posted by mschell View Post
    Every time I have connected to the E681, I've used a "regular" straight cable. The Wiznet figures out if it's directly connected or via a switch.
    Good to know. Thanks for the correction!
    Jun 2008
    Woodinville, WA
    149
    Deleted
    Mark Zembruski
    www.WoodinvilleWonderland.com
    I have the CLAP - Christmas Light Addiction Problem
    LOR - Lynx - Sandevice - J1Sys - Madrix - Advatek
    ~ Christmas is not a time, it's a state of mind ~
    10,283
    Quote Originally Posted by zman View Post
    Hey guys, running into the same issue with my E681. I have disabled the wireless on my laptop, but still no connection to the board. I have been communicating and setting it up by plugging it directly into my router, so I know I can talk to it.
    On my Laptop LAN, I have an TCP/IPv6 & TCP/IPv4. They both have the same set up. Any idea which one needs to be adjusted?
    Please provide a screenshot of the config screen - first thing to check is that the test pattern is disabled (it's on by default). Do a TE 0 and then SA 0. Also if you happen to be using pixels on the 4th socket (4-1/2/3/4) that they won't work while the web server is up.
    [/SIZE]
    [/COLOR][/I]
    Jun 2008
    Woodinville, WA
    149
    Brian, you must of had the page loaded in memory. I figured out that I had to edit the v4 entry, and deleted my post. I also modified the E681 to a IP of 192.168.100.10, and the Laptop LAN to 192.168.100.20 and now I can talk to the controller, and the wireless works as well.
    First major hurdle crossed.
    Mark Zembruski
    Feb 2008
    Pacific NW
    21
    And the reason for this is that most wireless network routers use the 192.168.1.x network for the IP addresses they give out, along with a subnet mask of 255.255.255.0. What that means is that all traffic for any address in the 192.168.1.1-255 range will go out on that connection. Your local Ethernet connection would have to be assigned a different subnet to have it work, and then couldn't talk to the default address of the E681.
    All that to say that you need to know a little about IP networking to be able to use more than one network connection at a time. That network connection could be two NIC cards with wired connections, or one wired connection and a wireless one.
    Disabling the wireless allows your wired connection to handle all the traffic, and so you can "talk" to the E681.
    Setting your E681 to a different subnet, such as 192.168.2.x, and setting your wired connection to the same subnet will allow both to work at the same time.
    Thats good information Mark.
    A couple of specifics - as asked and answered - a standard straight through cat 5 (or cat 6) cable will work just fine. It can be wired with either 568A or 568B specifications, either will work.
    Also - as you will see in later versions of MS Windows (7) - your TCP/IPv6 should be unchecked - for simplicity you want IPV4.
    If possible for ease of use allow your router to assign the IP address through DHCP. Then you can change the address to the static address you wish to use for your network. To help you find the address the router gave the device - you can look in the router table to find the new address. You can also install a free tool from SolarWinds called IP Tracker http://www.solarwinds.com/products/f...dress-tracker/.. Its a good tool in your tool box.
    Networking isn't hard, especially if you have a friend that will assist you when you hit a snag. Those of us that work with it daily sometimes forget what it took to learn, with that said - ask away!
    Papa's Christmas Workshop = > Lots of Lights! Lots of Fun! :D:D
    Lowell -
    10,283
    One other thing to play with is bridging the wired to wireless connection on your laptop. That way both the E68x and your regular internet/home network side are all on the same network. I didn't play with it too much but it seemed to work OK a while back. I personally plan on keeping the two on separate networks so I won't be using this myself. You can bridge the two adaptors under the control panel settings by ctrl-clicking both then right clicking and adding the bridge.
    [/SIZE]
    [/COLOR][/I]
    New Jersey
    1,395
    ...and one more thing. When using the "alternate method" you have to be patient. Sometimes it can take upwards of a minute for the Web Server to connect and be displayed. I get random times and don't know if it's the PC trying to connect to the Server, or if it's searching IP's or what the deal is... And in some cases the browser defaults to a search rather than a specific IP prior to connecting to the Web Server. Resubmitting the IP usually gets it to connect. I've had the same results on 4 E681's and had discussions with other E681 users of around 10 more of them behaving this way...
    Jeff
    Nov 2008
    Lexington, NC
    2,165
    Jeff
    It's possible to speed this process up by hitting the reset button on the E681. That will reset the board and the timer for the web server and have it stay up for the default amount of time.
    On my E681, the red LED for the web server lights up about every minute or so. You would need to hit the refresh button on your web browser quickly just after it comes back on.
    Mark
    New Jersey
    1,395
    When using the alternate method with a cable directly connected between laptop and E681, the very first thing you do is hit the reset button and at the same time hold the program button waiting for the red and green lights to both flash three times. It's at this point it takes up to a full minute for a connection to be made with the web server. So pressing the reset button wouldn't speed the process up, it would restart it the process from the beginning.
    Jeff
    10,283
    The Web Server by default will start up on boot-up and stay active for 5 minutes after initial boot or after the last web page access. If you are on the web page and want to use socket 4 then do a "QUIT" (or "QUIT 10") and it will quit after 10 seconds. You can also set up the web server to not start/run at all but you can use the mode buttons to turn it back on if you need to reconfigure it. Just keep this 5 minutes in mind when starting your shows if you do remote powering of the E68x (I leave all my stuff running 24x7...).
    [/SIZE]
    [/COLOR][/I]
