Results 1 to 10 of 11
Thread: ledtriks leds
    Mar 2009
    Terrytown,Nebraska
    471
    Default ledtriks leds
    Where can I get some leds for the ledtriks that are cheap and bright enough to be seen in the day time?
    Mar 2009
    Terrytown,Nebraska
    471
    Default Re: ledtriks leds
    Any help????????????????
    Feb 2008
    Warminster, PA
    1,298
    I've never used these in a Ledtriks but here's where I get my led's from.
    www.ledshoppe.com
    Jul 2008
    3,208
    no idea how the normal LEDs would look in the day time.
    However, you seem to be asking for the impossible...CHEAP and SUPERBRIGHT...they do not exist in the same universe.
    Oct 2009
    Nelson (New Zealand)
    200
    For what it is worth, the LED's suggested in the construction notes for the LedTricks panels, although very bright at night are virtually useless in the daylight from my experience. I have been considering wether LED's with the same spec'd brightness and a frosted lens rather than the water clear lens would do the trick ?? Just pondering, as I had hoped that my pair of LedTricks panels would be of use in the daytime as well :-)
    Cheers,
    Terry
    "Tory Street Lights", Nelson, NZ
    "Lucky Home" - 2012 Local Christmas Lighting Competition
    2012 :- 11 x Ren 64XC's - 550 Channels, 40,000+ lights. 2,500 or so LED's for the first time :-)
    2011:- 7 x Ren 64XC's - 384 Channels, 30,000+ lights - all incandescents! 2 x Commercial LED Panels (72x7)!
    "Supreme Winner for 2010" Local Christmas Lighting Competition
    2010:- 4 x Ren 64's - 256 Channels Controlled by Vixen - "Brilliant" :-)
    18,000 to 20,000 Lights - all incandescents! 2 x LedTricks Panels with "Pix C" interface's
    2009:- 128 Channels of "Hill 320", 4,000 Lights
    Mar 2009
    Terrytown,Nebraska
    471
    Quote Originally Posted by g2ktcf View Post
    Can't blame me for trying
    Sep 2007
    Iowa
    325
    The frosted LEDs are normally listed as "defused" and are not as bright as the clear.
    I have considered trying out some dark red window film to see if it improves the triks in daylight. Something like the red bezel on a LED calculator.
    -Craig
    Oct 2009
    200
    Hi Graig,
    That had passed through my mind as well, I guess as a trial a sheet of transparent Red Cellophane across the front would be worth a go and see how it works :-)
    Terry
    Rockford, IL
    313
    I'm far from an LED expert, but aren't the greens and blue LEDs a lot brighter than the reds? Does the color matter at all here? I made my triks using blue wide-angle clear leds and while it's not really visible if the sun is shining directly on it, it is defiantly readable during the day if kept in the shade. I'd imagine if you'd get LED's with a narrow field of view (think 40 degrees or less) than it would be even brighter. With all that said, the cheapest sources I've found are on eBay.
    Jun 2009
    Ottawa, Ontario, Canada
    2,494
    Keeping it mounted so that it is always in "shadow" was my approach. I stuck it over the garage door, but under the eaves. Net result, can be read during the day or night, and is/was well protected from the elements. Hope to double it's size this summer, by adding another length of pegboard, and a second triks controller.
    Standard Disclaimers apply:
