Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 74
Thread: My Pixel Tree The Beginnings (The edited version)
    Dec 2008
    Bairnsdale, Victoria , Australia
    261
    Default Re: My Pixel Tree The Beginnings (The edited version)
    shoot some pics of the drilling
    Sorry for the delay . Was sidetracked working on other elements of my display. My pixels arrived today so I made some final adjustments bought a small drill press and set it up tonight. Was going to use a step drill but found the small press doesnt have enough travel. So going to either get a new 12mm drill bit tomorrow or look at some other options to get a more precise hole. But took a couple of pics of the rig anyway.
    Fairly simple idea it consists of a drill press vice, a spare bit of steel plate and a 12mm bolt with its head removed .
    Once the first hole is drilled, it is moved onto the pin, then every other hole will be in perfect alignment.
    2012 Plans
    1 Pixel Megatree (Finished)
    20 x 3D Mini Trees
    40 x Mini Roof Stars (Finished)
    Columns (Qty to be decided)
    Pixels Pixels Pixels
    2011
    3 x RGB arches
    6 x RGB Window Display Trees
    2 x RGB Window Display Bells
    6 x RGb Window stars
    5 X Mini arches RGB
    1 x RGB Bethlehem Star
    14metres of Eave Lights
    Eagan, Mn.
    1,537
    Is that 120mm spacing your drilling?
    Brian
    Dec 2008
    261
    Yes it is 120 mm spacing . Would love to know how you worked that out from pics ?
    2012 Plans
    20 x 3D Mini Trees
    2011
    3 x RGB arches
    5 X Mini arches RGB
    Eagan, Mn.
    1,537
    Simple WAG. (Wild A$$ Guess). My pixels came with 120mm spacing (4.7 inch) and I'm still planning how to build my tree.
    So I've been watching closely. As I'm also looking at 180 half tree, 10 strings of 50 folded in half (so twenty strings).
    I was planning to pull them tight to keep them lined up but this looks like it would work out better.
    We'll see when you post a pic with the pixels installed and report how it works out.
    Brian
    Nov 2008
    Delphos OH
    1,171
    nice rig, i like it.
    so your drilling the holes and then going to cut in half?? how well they hold up after that?
    2012 - The year of the pixels
    21ft tall 12x38ct WS2811 Pixel Megatree - DONE
    5 36ct GECE Pixel Archs - Maybe
    Pixelated roofline with windows - DONE
    Bigger matrix and pixel star - DONE
    Added 1200 pixels, a few strobes, and fast tubes
    Now it just all has to play nicely lol.
    http://www.facebook.com/FiedlerFamilyChristmas
    Eagan, Mn.
    1,537
    Quote Originally Posted by fathead45 View Post
    If you went with a larger diameter you might be able to cut it in half. But as the hole is 12mm all the way thru and I believe I it was mentioned earlier that he's going to push them thru the back side. So I don't think he plans to cut them.
    Brian
    Nov 2008
    Delphos OH
    1,171
    ah ok missed that post lol.
    Eagan, Mn.
    1,537
    If you moved up to 3/4 inch or 1 inch I bet you could cut them in half.
    Might be easier to mount?
    Brian
    Nov 2008
    Delphos OH
    1,171
    eh since im doing the covers ill just strap to outside of pipe an call it a day lol
    Eagan, Mn.
    1,537
    Maybe glue the covers to the drilled pipe rather than the pixel?
    I think maybe your right, invest in a tie-wrap farm and wrap them to the pipe.
    I'm planning to do the GECE arches that way.
    Brian
