Results 1 to 10 of 25
Thread: Renard firmware Timer1
    Feb 2008
    Warminster, PA
    1,301
    Default Renard firmware Timer1
    I'm working on a small project that I'm editing the existing Renard firmward and I need to use timer1. My project is strictly using dc but I've come to realize that if it works for ac it could be of some use too.
    In the app notes in the beginning of the code it states that timer1 is not being used but down in the code timer1 gets initialized to count the interval between zero-crossings.
    I have removed(actually just remarked) all references to timer1. Will this have any impact on how the code dims(using ac)?
    I'm going to give it a try once I've ironed out my code, I just want to know if there's anything I should look for.
    Thanks!
    4,184
    Default Re: Renard firmware Timer1
    Yes, that code adjusts the timing to go along with the AC power-line frequency.
    4,184
    You might want to consider switching to the PIC16F1823. It is cheaper, has a compatible pinout, is faster, and has an extra timer. The internal register architecture is a bit different, and the firmware would take some work to make it run on that architecture.
    Feb 2008
    Warminster, PA
    1,301
    Ok, thanks Phil. I'll just stick with using it for DC purposes.
    1,763
    How do you want to use Timer1? You might be able to reuse or extend how Timer1 is currently being used without affecting the operation of the existing code.
    don
    Click for display details >>
    Feb 2008
    Warminster, PA
    1,301
    I'll look into that. Thanks again Phil.
    Feb 2008
    Warminster, PA
    1,301
    don
    I need it to get a 100ms or 50ms pulse. Currently the speed it is set up for is way too fast to get that.
    Nov 2010
    Placerville, CA
    1,826
    How about using it at the current setting and have the code count the pulses to get the timing you need? If it is set to 1MS, count 100 or 50 ticks and use THAT for your timing. Too fast is usually workable that way, too SLOW is what sucks (like it is set to 200MS and you need a 100 or 50MS timing).
    Kirk
    Apple Valley, MN
    3,220
    It's easy to waste time, a bit tougher to make it.
    Jun 2009
    Ottawa, Ontario, Canada
    2,504
    Unless your PIC is bigger on the inside than the outside... and/or you are working with Ponds.
    Standard Disclaimers apply:
