Results 1 to 6 of 6
Thread: RPM DMX 16 DCssr Help
    Default RPM DMX 16 DCssr Help
    Hi All,
    I am looking for help on RPM DMX 16DCssr board.
    Can I modify the board to run 5 volts. If so what do I need to do.
    Colin
    Pomona, California
    1,056
    Default Re: RPM DMX 16 DCssr Help
    Yes, the board can run on 5 volts as long as it's regulated and no higher than about 5.5vdc (the maximum voltage the processor can handle). You would need to bypass the on-board regulator (leave some of the components off the board) to do this.
    I don't have the schematic in front of me, so I'll have to look it up and get back to you on this.
    Robert
    Quote Originally Posted by cscool36 View Post
    Hi All,
    Colin
    1,499
    FWIW, I attempted it last holiday season and failed (as I do at so many things). I did have the schematic but apparently didn't understand the PS module correctly.
    I'm heartened that Robert thinks it can be done ... I've still got the board around here somewheres ;-) ...
    \dmc
    ________________________
    Pomona, California
    1,056
    Should be easy enough.... remove IC5 and add a jumper between the pads for pins 1 & 5. If building specifically for 5v input you can also delete C1,D2 & L1.
    Quote Originally Posted by dmcole View Post
    \dmc
    Thanks Robert,
    I will try this week.
    I Can not find IC 5 but have a IC 7 (LM2574). I am guessing that pin 1 is where the dot is.
    Can I leave in C1,D2 and L1?. or are they best to be let out. Do I need to bridge them as well.
    Also will you be making more circuit boards for this year?. Looking for some dmx 8dcssr.
    Colin
    Pomona, California
    1,056
    You are correct, I meant IC7 (LM2574) not IC5. I just rechecked it, and it seems I was looking at an earlier version of the schematic with different parts designations. Yes, pin 1 is marked by a dot on the board.
    If you already have C1,D2,L1 installed you can leave them in. It won't cause a problem with them in, but they aren't needed if removing the regulator (LM2574) IC.
    Robert
    Thanks Robert,
    Colin
