Results 21 to 30 of 32
Thread: E681 setup - High number of sequence errors.
    Worksop UK
    474
    Default Re: E681 setup - High number of sequence errors.
    Just done more tests.
    Each packet contains a sequence number that increments from 1 to 255 then loops back to 0. If a received packet doesn't have the expected sequence number, the sequence error count is incremented.
    Using Windows 7 32 bit - Vixen 2.1.4.0. - J1Sis 1.0.0.1. - E681 2.20. if I send 1 universe no errors if I send 2 or more unverses the error count is = packets recieved -1.
    Some how it looks like the packet addressing or the order is getting messed up when I send more than one universe. Is there an easy way to view the data thats being sent?
    2 X E681 running 8 universes of 3001s as a 32s x 42p mega tree or a 96s x 14p matrix hanging from my guttering.
    7,778
    Some how it looks like the packet addressing is getting messed up when I send more than one universe. Is there an easy way to view the data thats being sent?
    A couple choices - - SACNView does have a viewer - might have a logger as well but haven't checked. Another choice would be to download WireShark and kick off a packet capture and then start off your sequence - stop when you're satisfied and then take a look at what came out. Maybe compare between the single and 2x runs.
    Brian
    Halloween in San Jose! - FB
    Feb 2010
    Knoxville TN USA
    136
    OOOPS!!
    I just did a wireshark dump of the output of the plugin. It is doing a single sequence number across all universes. The spec calls for a sequence number PER universe.
    Wrong (current):
    Univ 101, Seq 0
    Univ 102, Seq 1
    Univ 103, Seq 2
    Univ 104, Seq 3
    Univ 101, Seq 4
    Univ 102, Seq 5
    Univ 103, Seq 6
    Univ 104, Seq 7
    Should be (according to my reading of the spec):
    Univ 101, Seq 0
    Univ 102, Seq 0
    Univ 103, Seq 0
    Univ 104, Seq 0
    Univ 101, Seq 1
    Univ 102, Seq 1
    Univ 103, Seq 1
    Univ 104, Seq 1
    I will issue a revise set of plugins for Vixen 2.1, 2.5, 3.0 ASAP. And will also advise the other software people who have based some of the driver on my code of the errata.
    So for now just ignore those error counts.
    My apologies,
    -Ed
    7,778
    Wow - wasn't expecting that to be the outcome! Nice follow-up Ed!
    Brian
    Royersford, PA (Philly)
    1,230
    This MIGHT explain some of the seq errors I see in LSP... it isn't an issue though, as the sequence still plays back! Thanks for looking into this Ed!
    For others future reference, all of the above troubleshooting steps that everyone has posted are great places to start!
    Oct 2009
    Savannah, GA
    427
    I use WireShark for debugging my E1.31 packets. It has an ACN decoder to help find these types of errors. Open Edit->Preferences->Protocols->ACN and enable the "Decode ACN" and "Streaming DMX" options and restart WireShark.
    Worksop UK
    474
    Hi, all it looks like we've bottomed this one.
    Thanks for all the advice and comments. I have a couple of new bits of software in the toolbox and a greater understanding of my setup - I did wonder how I'd managed to break something that everyone else had got to work though.
    It's good to know that Ed is sorting the indexing - thanks Ed it's an invaluable plugin. I'm on holiday but will look forward to giving it a try when I get home.
    Pomona, California
    1,056
    I have always noticed these errors as well, but always figured it was something in the sending app for the same reasons noted... this just confirms it.
    Since the sequence number field is 1 byte in the E1.31 framing layer, this can only be 0-9 so I can see where this could cause problems with multiple universes as well.
    Ed, which document shows the sequence details? The ESTA BSR-E1.31 I have doesn't show this detail.
    Quote Originally Posted by j1sys View Post
    OOOPS!!
    Wrong (current):
    Univ 101, Seq 0
    Univ 102, Seq 1
    Univ 103, Seq 2
    Univ 104, Seq 3
    Univ 101, Seq 4
    Univ 102, Seq 5
    Univ 103, Seq 6
    Univ 104, Seq 7
    Univ 101, Seq 0
    Univ 102, Seq 0
    Univ 103, Seq 0
    Univ 104, Seq 0
    Univ 101, Seq 1
    Univ 102, Seq 1
    Univ 103, Seq 1
    Univ 104, Seq 1
    My apologies,
    -Ed
    Quote Originally Posted by RPM View Post
    From ANSI E1.31 2009:
    "Sources shall maintain a sequence for each universe they transmit. The sequence number for a universe
    shall be incremented by one for every packet sent on that universe."
    It's a 1-byte field so sequence numbers range from 0-255.
    The Sandevices E680/E681/E682 Pixel Controllers, part of the PIXEL PROJECT
    www.sandevices.com
    <-email jim at
    Pomona, California
    1,056
    Ahhh.... I just noticed the spec shows it as an octet, so this would be correct. My bad.
    Quote Originally Posted by jstjohnz View Post
