Results 11 to 20 of 29
Thread: arduino on WIFI with vixen drivers for g35 lights
    Southeast Missouri
    56
    Default
    I have code for dmx on arduino.
    Sent from my Motorola Atrix2 via Tapatalk 2
    Proud user of Controlling 1289 Channels with a total of 9500 lights.
    Default Re: arduino on WIFI with vixen drivers for g35 lights
    WIll you share the code here?
    Pacifica, Calif (30mins from downtown San Francisco)
    1,502
    Quote Originally Posted by roboengr View Post
    There are two Arduino code bases for DMX reception:
    *Max Pierson's work from a couple of years ago -- see http://blog.wingedvictorydesign.com/...th-an-arduino/
    *Hendrick Hoelscher (aka Henne) work for ATMegas that was ported to Arduino. The code evolved over a number iterations and is documented at http://www.arduino.cc/cgi-bin/yabb2/...1223117506/all ... read from the end forward, as the first posted code doesn't work.
    \dmc
    ________________________
    The only thing more dangerous than a software engineer with a soldering iron
    or a hardware engineer with a compiler is a liberal-arts major with either.
    Christmas lights: http://www.PacificaLights.info/
    uC/LED hacking: http://www.dmcole.net/
    Southeast Missouri
    56
    Default
    I can share my sketch for reading dmx and using it to control 2 G35 color effects.
    Durham, North Carolina
    245
    Quote Originally Posted by mimir View Post
    That would be awesome. Does it read dmx from a dmx controller?
    Southeast Missouri
    56
    When I was testing it, I used a usb to dmx dongle to produce the dmx data driven by vixen and/or xlights. Give me a bit to check it out again and then I will upload the code.
    I wrote and tested this on an arduino uno based on the code Max Pierson developed. The code has the starting address hard coded in it currently. There is code in it for setting the address externally, but I have not tested that part.
    The GE strings I have are all 36 pixels, and that number is also hard coded, but easily changed.
    so what I have is one uno board controlling 216 channels (channel 1,2,3 are node 1, 4,5,6 = node 2, etc) up to 108 being node 36 on the first string.
    109,110, 111 = node 1 on string 2.
    Southeast Missouri
    56
    Here is the code I wrote/adapted. Hope this helps.
    Code:
    * DMX-512 Reception based on code Developed by Max Pierson
    * GE CE G35 code based on code by Robert Quattlebaum <darco@deepdarc.com>
    * and Scott Harris <scottrharris@gmail.com>
    * Version 1.0 January 12, 2012
    * Author: John Abate
    // This program controls two equal length GE Color Effects G35 RGB LED light strings from
    // dmx input
    /******************************* Addressing variable declarations *****************************/
    #include <EEPROM.h>
    #define SWITCH_PIN_0 11 //the pin number of our "0" switch
    #define SWITCH_PIN_1 12 //the pin number of our "1" switch
    #define xmas_color_t uint16_t // typedefs can cause trouble in the Arduino environment
    // These are the defines needed for the RGB Lights
     #define XMAS_LIGHT_COUNT          (36) //I only have a 36 light strand. Should be 50 or 36
     #define XMAS_CHANNEL_MAX          (0xF)
     #define XMAS_DEFAULT_INTENSITY     (0xCC)
     #define XMAS_MAX_INTENSITY         (0xCC)
     #define XMAS_HUE_MAX               ((XMAS_CHANNEL_MAX+1)*6-1)
     #define XMAS_COLOR(r,g,b)     ((r)+((g)<<4)+((b)<<8))
     #define XMAS_COLOR_WHITE     XMAS_COLOR(XMAS_CHANNEL_MAX,XMAS_CHANNEL_MAX,XMAS_CHANNEL_MAX)
     #define XMAS_COLOR_BLACK     XMAS_COLOR(0,0,0)
     #define DELAYLONG 17 //DigitalWrite takes ~ 3.4us
     #define DELAYSHORT 6
     #define ZERO(pin) digitalWrite(pin,LOW); delayMicroseconds(DELAYSHORT); digitalWrite(pin,HIGH); delayMicroseconds(DELAYLONG);
     #define ONE(pin) digitalWrite(pin,LOW); delayMicroseconds(DELAYLONG); digitalWrite(pin,HIGH); delayMicroseconds(DELAYSHORT);
     #define XMASPIN 4 // I drive the LED strand from pin #4
     #define XMASPIN2 7 // I drive the LED strand 2 from pin #5
     #define NUMBER_OF_CHANNELS  XMAS_LIGHT_COUNT * 3 * 2
     int bulb = 0;
     int j = 2;
    unsigned int dmxaddress = 1;
    /* The dmx address we will be listening to.  The value of this will be set in the Addressing()
    *  function, if triggered, and read from EEPROM addresses 510 and 511.
    /******************************* MAX485 variable declarations *****************************/
    #define RECEIVER_OUTPUT_ENABLE 2
    /* receiver output enable (pin2) on the max485.
    *  will be left low to set the max485 to receive data. */
    #define DRIVER_OUTPUT_ENABLE 3
    /* driver output enable (pin3) on the max485.
    *  will left low to disable driver output. */
    #define RX_PIN 0   // serial receive pin, which takes the incoming data from the MAX485.
    #define TX_PIN 1   // serial transmission pin
    /******************************* DMX variable declarations ********************************/
    volatile byte i = 0;              //dummy variable for dmxvalue[]
    volatile byte dmxreceived = 0;    //the latest received value
    volatile unsigned int dmxcurrent = 0;     //counter variable that is incremented every time we receive a value.
    volatile byte dmxvalue[NUMBER_OF_CHANNELS+2];     //stores the DMX values we're interested in using.
    volatile boolean dmxnewvalue = false; //set to 1 when new dmx values are received.
    /******************************* Timer2 variable declarations *****************************/
    volatile byte zerocounter = 0;
    /* a counter to hold the number of zeros received in sequence on the serial receive pin.
    *  When we've received a minimum of 11 zeros in a row, we must be in a break.  As written,
    *  the timer2 ISR actually checks for 22 zeros in a row, for the full 88uS break.       */
    void Addressing(byte switch0, byte switch1)
    byte bitnumber = 0; //the number of bits recorded so far
    boolean blink = 0; //used to blink the pin 13 LED once the address is recorded.
    if (switch0 == 0 && switch1 == 0)
      EEPROM.write(510, lowByte(dmxaddress));
      EEPROM.write(511, highByte(dmxaddress));
      //if BOTH addressing switches are held down, the starting address is reset to 1.
    else if (switch0 == 0 ^ switch1 == 0)
      /* if EITHER switch0 or switch1 is held down (but not both), the addressing subroutine is
      *  run.  Since it writes the new address into EEPROM, there's no need to pass anything
      *  back to the main function. */
      while (bitnumber < 9) //runs 9 times, recording a bit in dmxaddress each time.
        digitalWrite(13, HIGH); //turn on pin 13 to indicate addressing mode.
        if (switch0 != digitalRead(SWITCH_PIN_0) || switch1 != digitalRead(SWITCH_PIN_1))
          //execute loop if either switch state has changed
              if (digitalRead(SWITCH_PIN_0) == HIGH && digitalRead(SWITCH_PIN_1) == LOW)
                  //execute if 1 pin is pressed
                  switch0 = digitalRead(SWITCH_PIN_0);
                  switch1 = digitalRead(SWITCH_PIN_1);  //update switch state variables with the new state
                  bitSet(dmxaddress, bitnumber);  //write a 0 to the appropriate bit of dmxaddress
                  bitnumber++;
                  digitalWrite(13, LOW); //flash off pin 13 to indicate bit accepted
                  delay(500);
              if (digitalRead(SWITCH_PIN_0) == LOW && digitalRead(SWITCH_PIN_1) == HIGH)
                  //execute if 0 pin is pressed
                  bitClear(dmxaddress, bitnumber);  //write a 0 to the appropriate bit of dmxaddress
                  bitnumber++;
                  digitalWrite(13, LOW); //turn off pin 13 to indicate bit accepted
                  delay(500);
          } //end switch state change if statement
        } //end while loop
      }//end else if addressing subroutine
    for (byte i = 0; i < 15; i++) //blink LED 4 times when new address is received.
      digitalWrite(13, blink);
      delay(100);
      blink = ~blink;
    EEPROM.write(510, lowByte(dmxaddress));//writes the first byte of dmxaddress to EEPROM address 510
    EEPROM.write(511, highByte(dmxaddress));//writes the second byte of dmxaddress to EEPROM address 511
    return;
    }  //end Addressing()
    void setup() {
      /******************************* Max485 configuration ***********************************/
      pinMode(XMASPIN, OUTPUT);
      pinMode(XMASPIN2,OUTPUT);
      int i = 0;
      delay(500);
      // The way the GE CE lights get their addressing is from the first set of data
      // send to them after power up.  This code cycles through each bulb setting it to RED
      // then GREEN and then BLUE followed by setting them all to BLACK
      // If you do not want the RGB seqence on power up, then remove all but the last loop
      // which will accomplish the node addressing without lighting up the nodes.
      for(i = 0;i<XMAS_LIGHT_COUNT;i++)
        SETBULB(XMASPIN,i,0xCC,255,0,0);
        SETBULB(XMASPIN2,i,0xCC,255,0,0);
      delay(100);
        SETBULB(XMASPIN,i,0xCC,0,255,0);
        SETBULB(XMASPIN2,i,0xCC,0,255,0);
      delay(100);
        SETBULB(XMASPIN,i,0xCC,0,0,255);
        SETBULB(XMASPIN2,i,0xCC,0,0,255);
      delay(100);
      for(int i = XMAS_LIGHT_COUNT-1;i>=0;i--)
        SETBULB(XMASPIN,i,0xCC,0,0,0);
        SETBULB(XMASPIN2,i,0xCC,0,0,0);
      pinMode(RECEIVER_OUTPUT_ENABLE, OUTPUT);
      pinMode(DRIVER_OUTPUT_ENABLE, OUTPUT);
      digitalWrite(RECEIVER_OUTPUT_ENABLE, LOW);
      digitalWrite(DRIVER_OUTPUT_ENABLE, LOW);    //sets pins 3 and 4 to low to enable reciever mode on the MAX485.
      pinMode(RX_PIN, INPUT);  //sets serial pin to receive data
      /******************************* Addressing subroutine *********************************/
      pinMode(SWITCH_PIN_0, INPUT);           //sets pin for '0' switch to input
      digitalWrite(SWITCH_PIN_0, HIGH);       //turns on the internal pull-up resistor for '0' switch pin
      pinMode(SWITCH_PIN_1, INPUT);           //sets pin for '1' switch to input
      digitalWrite(SWITCH_PIN_1, HIGH);       //turns on the internal pull-up resistor for '1' switch pin
      byte switch1 = 0;
      byte switch0 = 0;  //the switch states for the 1 and 0 pin
      if (switch0 == 0 || switch1 == 0)
      Addressing(switch0, switch1);
      //call the addressing subroutine if either switch is pressed.
      //read the previously stored value from EEPROM addresses 510 and 511.
      dmxaddress = EEPROM.read(511);   //read the high byte into dmxaddress
      dmxaddress = dmxaddress << 8;
      //bitshift the high byte left 8 bits to make room for the low byte
      dmxaddress =  dmxaddress | EEPROM.read(510);   //read the low byte into dmxaddress
      dmxaddress = dmxaddress + 3;
      /*  this will allow the USART receive interrupt to fire an additional 3 times for every dmx frame.
      *   Here's why:
      *   Once to account for the fact that DMX addresses run from 0-511, whereas channel numbers
      *        start numbering at 1.
      *   Once for the Mark After Break (MAB), which will be detected by the USART as a valid character
      *        (a zero, eight more zeros, followed by a one)
      *   Once for the START code that precedes the 512 DMX values (used for RDM).  */
      /******************************* USART configuration ************************************/
      Serial.begin(250000);
    //Serial.begin(115200);
    //Serial.begin(57600);
      /* Each bit is 4uS long, hence 250Kbps baud rate */
      cli(); //disable interrupts while we're setting bits in registers
      bitClear(UCSR0B, RXCIE0);  //disable USART reception interrupt
      /******************************* Timer2 configuration ***********************************/
      //NOTE:  this will disable PWM on pins 3 and 11.
      bitClear(TCCR2A, COM2A1);
      bitClear(TCCR2A, COM2A0); //disable compare match output A mode
      bitClear(TCCR2A, COM2B1);
      bitClear(TCCR2A, COM2B0); //disable compare match output B mode
      bitSet(TCCR2A, WGM21);
      bitClear(TCCR2A, WGM20);  //set mode 2, CTC.  TOP will be set by OCRA.
      bitClear(TCCR2B, FOC2A);
      bitClear(TCCR2B, FOC2B);  //disable Force Output Compare A and B.
      bitClear(TCCR2B, WGM22);  //set mode 2, CTC.  TOP will be set by OCRA.
      bitClear(TCCR2B, CS22);
      bitClear(TCCR2B, CS21);
      bitSet(TCCR2B, CS20);   // no prescaler means the clock will increment every 62.5ns (assuming 16Mhz clock speed).
      OCR2A = 64;
      /* Set output compare register to 64, so that the Output Compare Interrupt will fire
      *  every 4uS.  */
      bitClear(TIMSK2, OCIE2B);  //Disable Timer/Counter2 Output Compare Match B Interrupt
      bitSet(TIMSK2, OCIE2A);    //Enable Timer/Counter2 Output Compare Match A Interrupt
      bitClear(TIMSK2, TOIE2);   //Disable Timer/Counter2 Overflow Interrupt Enable
      sei();                     //reenable interrupts now that timer2 has been configured.
    }  //end setup()
    void loop()  {
      // the processor gets parked here while the ISRs are doing their thing.
      if (dmxnewvalue == true) {    //when a new set of values are received, jump to action loop...
        action();
        dmxnewvalue = 0;
        dmxcurrent = 0;
        zerocounter = 0;      //and then when finished reset variables and enable timer2 interrupt
        i = 0;
    } //end loop()
    //Timer2 compare match interrupt vector handler
    ISR(TIMER2_COMPA_vect) {
      if (bitRead(PIND, PIND0)) {  // if a one is detected, we're not in a break, reset zerocounter.
        zerocounter = 0;
      else {
        zerocounter++;             // increment zerocounter if a zero is received.
        if (zerocounter == 22)     // if 22 0's are received in a row (88uS break)
          bitClear(TIMSK2, OCIE2A);    //disable this interrupt and enable reception interrupt now that we're in a break.
          bitSet(UCSR0B, RXCIE0);
    } //end Timer2 ISR
    ISR(USART_RX_vect){
      dmxreceived = UDR0;
      /* The receive buffer (UDR0) must be read during the reception ISR, or the ISR will just
      *  execute again immediately upon exiting. */
      dmxcurrent++;                        //increment address counter
      if(dmxcurrent > dmxaddress) {         //check if the current address is the one we want.
        dmxvalue[i] = dmxreceived;
        i++;
        if(i == NUMBER_OF_CHANNELS+2) {
          dmxnewvalue = true;                        //set newvalue, so that the main code can be executed.
    } // end ISR
      void xmas_set_color(uint8_t led,uint8_t intensity,xmas_color_t color)
        uint8_t R, G, B;
        R = color & 0x0F;
        G = (color >> 4) & 0x0F;
        B = (color >> 8) & 0x0F;
        //xmas_set_color(begin++,intensity,color);
        SETBULB(XMASPIN,led,intensity, R,G,B);
     xmas_color_t
     xmas_color(uint8_t r,uint8_t g,uint8_t b)
          return XMAS_COLOR(r,g,b);
     void SETBULB( byte IOPin, byte Bulb, byte Brightness, byte R, byte G, byte B)
        R = R>>4;
        G = G>>4;
        B = B>>4;
        digitalWrite(IOPin,HIGH);
        //Bulb
        if (Bulb & 0x20) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Bulb & 0x10) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Bulb & 0x08) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Bulb & 0x04) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Bulb & 0x02) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Bulb & 0x01) { ONE(IOPin) } else { ZERO(IOPin) };
        //Brightness
        if (Brightness & 0x80) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x40) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x20) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x10) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x08) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x04) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x02) { ONE(IOPin) } else { ZERO(IOPin) };
        if (Brightness & 0x01) { ONE(IOPin) } else { ZERO(IOPin) };
        //Blue
        if (B & 0x8) { ONE(IOPin) } else { ZERO(IOPin) };
        if (B & 0x4) { ONE(IOPin) } else { ZERO(IOPin) };
        if (B & 0x2) { ONE(IOPin) } else { ZERO(IOPin) };
        if (B & 0x1) { ONE(IOPin) } else { ZERO(IOPin) };
        //Green
        if (G & 0x8) { ONE(IOPin) } else { ZERO(IOPin) };
        if (G & 0x4) { ONE(IOPin) } else { ZERO(IOPin) };
        if (G & 0x2) { ONE(IOPin) } else { ZERO(IOPin) };
        if (G & 0x1) { ONE(IOPin) } else { ZERO(IOPin) };
        //Red
        if (R & 0x8) { ONE(IOPin) } else { ZERO(IOPin) };
        if (R & 0x4) { ONE(IOPin) } else { ZERO(IOPin) };
        if (R & 0x2) { ONE(IOPin) } else { ZERO(IOPin) };
        if (R & 0x1) { ONE(IOPin) } else { ZERO(IOPin) };
        digitalWrite(IOPin,LOW);
        delayMicroseconds(40);
    void action() {
      j = 2;
    for(bulb = 0; bulb < XMAS_LIGHT_COUNT; bulb++)
        SETBULB(XMASPIN,bulb,0xCC,dmxvalue[j++],dmxvalue[j++],dmxvalue[j++]);
    // strand 2
        SETBULB(XMASPIN2,bulb,0xCC,dmxvalue[j++],dmxvalue[j++],dmxvalue[j++]);
      return;  //go back to loop()
    } //end action() loop
    Sep 2010
    Clear Lake, TX
    211
    What version of the Arduino IDE are you using, I'm using 022? When I compile for the Mega I have no problems. When compiling for the Uno I get the following errors. I'm not sure what __vector_18 is.
    core.a(HardwareSerial.cpp.o): In function `__vector_18':
    C:\Users\btowner\Documents\Applications\Arduino\ar duino-0022\hardware\arduino\cores\arduino/HardwareSerial.cpp:81: multiple definition of `__vector_18'
    sketch_may25a.cpp.o:C:\Users\btowner\AppData\Local \Temp\build5135775376631536600.tmp/sketch_may25a.cpp:301: first defined here
    Well done! You will become the WiznetWizard!
    Level UP!
  9. #19
    Sep 2010
    Clear Lake, TX
    211
    @mimir
    This is great. I can't wait to try it this weekend. I have a Mega2560 so at least I can test. I've never worked with DMX so it'll be interesting.
    Level UP!
  10. #20
    Southeast Missouri
    56
    Default
    The IDE is 1.0 if I remember correctly. I am at work, will double check when I get home.
