Thread: Minimun System Requirements for Vixen 3.0 ????
    Sep 2011
    Moultrie, GA
    81
    Default Minimun System Requirements for Vixen 3.0 ????
    Is there a Minimun System Requirements (CPU Speed, HD & RAM size, etc.) for Vixen 3.0 ???
    Thanks a lot
    Marcos D. Valega
    2008-2010: Static 1,750 Inca & LEDs
    2011: Found DIYC - 1 Mega Tree w/DVDs Star - 2,500 LEDs & became a Supporting Member
    2012: 5,400 LEDs and Counting - Mega Tree, 3 Leaping Arches with Poles, 1 RenSS24 & 5 RenSS16 with XBee Snap-In Kits
    Oceanside, CA
    2,091
    Default Re: Minimun System Requirements for Vixen 3.0 ????
    I'm not sure about minimum, but read my last post here for a bit of information on my specs/channel count: http://doityourselfchristmas.com/for...294#post203294
    The perfect is the enemy of the good. -Voltaire
    Jul 2008
    Brisbane, Australia
    643
    Not really any minimum HW specs: the minimum will be Windows XP and .NET 4.0, and whatever is needed to run that.
    Mind you, the hardware required will wildly vary based on what you're trying to do with the software. If you're trying to run a simple show with 8 or 16 channels, no overly complex effects or crazy color things happening, etc., then a 10-year old PC with 512MB of RAM would most likely be fine. If you're trying to run a super-fancy high-tech display, with thousands of channels for pixel-addressable displays, complex effects, patching, breakdowns, etc., etc., etc., then you'll probably want a more modern machine -- maybe something within the last few years, and with plenty of RAM.
    In the middle of those two extremes, though? Anyone's guess, I purposely avoided it. ;-) It'll be mostly a try-it-and-see.
