Results 11 to 20 of 27
Thread: Nutcracker: Tutorials
    Littleton, Colorado
    864
    Default Re: Nutcracker: Tutorials
    Hi Sean, Now I've a copy of Vixen 2.1 and a couple of nutcracker files. I tried a copy paste onto the grid and got nothing. So I added it to the sequence directory. Can't seem to figure out how to import into Vixen 2.1 Has anyone else gotten past this point yet?
    Brian
    I think the process is like this:
    1) Produce a vir file from Nutcracker. Save it to the routines directory under your Vixen 2.1.1.0 home.
    NOT your Sequences directory.
    You really should really get the three addons that Emmanuel wrote, they are awesome!
    http://emmanuelmiranda.info/?page_id=10
    download the Vixen 2.1
    Unzip the file and you will have three addons
    RGBProfilerAddin.dll <= This will create a profile from your vir file. It gets everything to be RGB, labels all the channels for you
    RoutineLoaderAddin.dll <= Trying to load large routine files causes some problems for Vixen. Emmanuel wrote code that can instantly load the huge vir files with no issues
    Both of these should be moved into your Addins directory
    RGBTreePreview3d.dll <= This will create a 3D tree that looks the same as my animated gifs. very cool.
    This should be moved into your plugins/output directory
    You should look at the tutorial at http://www.youtube.com/watch?feature...&v=_GEC3hrhHyY
    Than Emmanuel has posted
    Sean
    Highlands Ranch, CO
    Nutcracker RGB Sequence Builder http://nutcracker123.com/nutcracker
    Build your own 9' Nutcracker http://meighan.net/build_your_own_nutcrackers
    Eagan, Mn.
    1,513
    Quote Originally Posted by smeighan View Post
    Yes that works and Emanuel's software works great! First ten seconds looks good. Now to do a few more into a test sequence.
    Then finish the E681. Lay some lights on the floor and try to get everyone talking to each other.
    Thank you again Sean!!
    Eagan, Mn.
    1,513
    Hi Sean, Can you check out one of my effects? I've imported Test+Snow, Test+Spiral, Test+Spiral3, Test+Butterfly without trouble and they preview in Emanuel's software fine.
    But my Test+Garland when I put it in the routines directory and try to use "any" routine I get a error. The error box say's "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Parameter must be positive and < Width. Parameter: x "
    And here's some exerts from the details box.
    System.ArgumentOutOfRangeException: Parameter must be positive and < Width.
    Parameter name: x
    at System.Drawing.Bitmap.SetPixel(Int32 x, Int32 y, Color color)
    at Vixen.Dialogs.Routine..ctor(String filePath)
    at Vixen.Dialogs.RoutineSelectDialog..ctor()
    at StandardSequence.StandardSequence.GetRoutine()
    at StandardSequence.StandardSequence.loadARoutineTool StripMenuItem_Click(Object sender, EventArgs e)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Vixen
    Assembly Version: 2.1.4.0
    Win32 Version: 2.1.4.0
    CodeBase: file:///C:/Users/mdtbxs1/Downloads/Vixen%202.1.1.0/Vixen%202.1.1.0/Vixen.exe
    What do you think?
    Brian
    Nov 2010
    Ponce, Puerto Rico
    141
    When are you getting this error? How are you importing the routines, by right clicking a grid and selecting Load a routine or by using my plugin?
    Parameter name: x
    mscorlib
    Vixen
    What do you think?
    Brian
    RGB Mega Tree Plugin: www.emmanuelmiranda.info
    Eagan, Mn.
    1,513
    Quote Originally Posted by nuelemma View Post
    Yes, I'm right clicking on the grid, selecting load a routine. If the Test+Garland file is in the routine directory I get the error. If I move the file somewhere else or delete it, I get a list of routines to select.
    Brian
    Nov 2010
    Ponce, Puerto Rico
    141
    Brian
    This sounds like the "space at the first line end error"
    Open the .vir file on notepad or any text editor. Then check if the first line has a space after last digit. Add one space if there is no space. Then save an try again.
    Emmanuel
    Eagan, Mn.
    1,513
    Emmanuel
    I couldn't tell if there was a space or not. But I added one, saved file. Opened Vixen and still get the same error.
    Brian
    Nov 2010
    Ponce, Puerto Rico
    141
    Brian
    Can You PM the file or post it here?
    Littleton, Colorado
    864
    I couldnt remeber if there was supposed to be a space on the last line or not. I accidentally edited that out.
    I have put the space back as the last character and released the code.
    try again
    Sean
    Highlands Ranch, CO
    Eagan, Mn.
    1,513
    Tried to make a new file from Nutcracker again, twice changed timing on the second one. Neither worked with Vixen. Same error. Tried to PM and post file but DIYC won't let me post it either way.
    Brian
