Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Nutcracker: Tutorials
    Littleton, Colorado
    2,592
    Default Nutcracker: Tutorials
    To find the tutorials about xlights and Nutcracker. Go to vimeo.com and search for "sean meighan". all the newest and the complete list be shown to you.
    Sean
    Littleton, CO
    Latest releases [url]http://nutcracker123.com/nutcracker/releases[/url]
    xLights/Nutcracker Forum [url]http://nutcracker123.com/forum/index.php[/url]
    Facebook [url]https://www.facebook.com/groups/628061113896314[/url]
    [IMG]http://nutcracker123.com/nutcracker/images/ZZ_SEAN5.gif[/IMG]
    Littleton, Colorado
    2,592
    Default Re: Nutcracker: Tutorials
    Ok, Now we come to the tutorials that have more substance on them
    Tutorial #2. Creating a target model http://meighan.net/nutcracker/tutorials/tutorial2.swf
    Tutorial #3. Creating a target model (continued) http://meighan.net/nutcracker/tutorials/tutorial3.swf
    Tutorial #4. Creating an Effect http://meighan.net/nutcracker/tutorials/tutorial4.swf
    Tutorial #5. Creating an Effect (continued) http://meighan.net/nutcracker/tutorials/tutorial5.swf
    Tutorial #6. Exporting your sequence http://meighan.net/nutcracker/tutorials/tutorial6.swf
    enjoy
    Sean
    Littleton, CO
    Iowa
    185
    I like your quote "I'm gonna use 16 strings because I got a lot of money... not" ROFL
    Great tutorials though. They really help to clarify some details.
    Dream Bigger
    Spencer Iowa
    1,236
    Link for #1 is broken
    #2 and #4 end before they are finished.
    A feature request which the program probably already knows.
    Instead of asking for the duration, have an option for one revolution or cycle only.
    A spiral will repeat after it makes one revolution.
    The garland or hoop pattern resets when it gets to the top.
    Setting the length to only one cycle would cut down on the generation time, and reduce the file sizes as redundant data is eliminated.
    Would also make it easier to repeat an effect for an extended period, as you would not have to worry about aligning the splices of one cycle to the next.
    Might also be a good idea to only put snapshots in the gallery, then click thru to see the full effect in action.
    50 animated GIFs are kind of killing that page.
    Joel
    UK S80 postcode
    1,463
    That would be realy cool, and even better if the routine importing tool could import x times, based on # of rotations or time.
    I'm sorry, you do lots of work and we just ask for more.
    Littleton, Colorado
    2,592
    Quote Originally Posted by jrock64 View Post
    Joel
    thanks for the feed back joel.
    For what effect?
    spirals, i only generate as many frames as one rotation. When you then request a 5 second sequence, the output logic just reads the data file multiple times.
    meteors, i currently create 80 frames. each frame generates a random number of meteors. after the 80 are finished , it repeasts them again. Again, for output if 80 frames does not create a long enough sequence, the make_lor.php, make_vixen.php routines just read the data file again.
    butterfly, again i am creating 80 frames. This morphing color would continue foreverer, if we let it.
    garlands, same as meteors. 80 frames
    I have thought of prompting for the number of frames you might want for any animation.
    I wrote code to wait until the garland reached the top, i was getting 250-400 frames of animation depending on how you answered the form. This could not finish in under 30 seconds.
    spiral already does one rotation. If there are 32 strands, then there are 32 frames.
    /Might also be a good idea to only put snapshots in the gallery, then click thru to see the full effect in action.
    I agree. I will do two fixes
    1) short term, only display 30-40 gifs at a time, have next 40 button
    2) Create thumbnails of the animated gifs. This requires that i modify the gnuplot program, blah, blah, blah. This will take longer but is the better solution.
    thanks
    again
    Sean
    Littleton, CO
  7. Thanks intwoit2002 thanked for this post
  8. #7
    Littleton, Colorado
    2,592
    new tutorials added. #7,8 and 9
    Tutorial #1. Overview of Nutcracker and creating an account http://meighan.net/nutcracker/tutorials/tutorial1.swf
    Tutorial #4. Creating an Effect, BUTTERFLY (Part 1) http://meighan.net/nutcracker/tutorials/tutorial4.swf
    Tutorial #5. Creating an Effect, BUTTERFLY (Part 2) http://meighan.net/nutcracker/tutorials/tutorial5.swf
    new added 3-21-12 13:00
    Tutorial #7. Creating an Effect, SPIRALS (Part 1) http://meighan.net/nutcracker/tutorials/tutorial7.swf
    Tutorial #8. Creating an Effect, SPIRALS (Part 2) http://meighan.net/nutcracker/tutorials/tutorial8.swf
    Tutorial #9. Creating an Effect, TEXT http://meighan.net/nutcracker/tutorials/tutorial9.swf
    Sean
    Littleton, CO
  9. #8
    Eagan, Mn.
    4,073
    Quote Originally Posted by smeighan View Post
    enjoy
    Hi Sean, Now I've a copy of Vixen 2.1 and a couple of nutcracker files. I tried a copy paste onto the grid and got nothing. So I added it to the sequence directory. Can't seem to figure out how to import into Vixen 2.1 Has anyone else gotten past this point yet?
    Brian
  10. #9
    Nov 2010
    Ponce, Puerto Rico
    209
    You need to save the generated file from the nutcracker into the Routines folder. Then on the sequence, select and right click on the desired cell and click Load a Routine, you should see the downloaded file on the list.
    RGB Mega Tree Plugin: www.varaderolights.com
  11. #10
    Eagan, Mn.
    4,073
    Quote Originally Posted by nuelemma View Post
    Thank you very much! Now I've more to figure out. Step by step I'll get there.
    Brian
