Results 21 to 30 of 35
Thread: Scary Terry sound to servo board
    Carver, MA
    196
    Default
    Is there a way to test voltage on the 3 pins for the servo? To see if output is correct.
    Nov 2008
    Peru, Indiana
    525
    Default Re: Scary Terry sound to servo board
    Pin 3 of the servo header is a PWM signal and would require a scope to get a proper reading. I have been looking at your picture and am having trouble following the wiring. Its difficult to tell where all of the wires go. I see several very large solder blobs that may be shorts but I cant tell for sure. I think the best thing to do at this point is get a meter out and start taking some readings.
    you should have 5 volts at the following places:
    LM4558 pin #8
    4066 pin #14
    555 pin #4 and 8
    with the power disconnected you should have 0 ohms of resistance to ground at the following places:
    LM4558 pin #4
    4066 pins 2,5,6, and 7
    555 pin 1
    Blinky Flashy on a budget since 2009
    2009: 32 channels of Grench
    2010: 80 channels of home etched Ren-16 Simple and Home etched SSRneons.
    [URL="http://www.vimeo.com/user2720474/videos"]My videos [/URL]
    May 2009
    Oklahoma
    60
    Quote Originally Posted by LightUpMA View Post
    Yea 2 pins should be power, and one signal.
    B= -
    R= +
    Y= Signal
    You can use a voltage meter to make sure the voltage is correct by sticking the probes on B and R. But y requires a different tactic.
    Carver, MA
    196
    Default
    Quote Originally Posted by tstraub View Post
    LM4558 pin #8
    4066 pin #14
    555 pin #4 and 8
    LM4558 pin #4
    555 pin 1
    Well the big blobs are solder bridges between two points close by that are suppose to be connected. I'm so frustrated lol. I remember reading a while back about a board house that will build small boards I think 3x3 for low fees. About to have one made up.
    I'll do those tests u suggested and then make sure no solder bridges.
    Thanks again Tyler!
    Carver, MA
    196
    Default
    LM4558 pin #8
    4066 pin #14
    555 pin #4 and 8
    LM4558 pin #4
    555 pin 1
    I have 5 volts at all those places but oddly I tested red and black pins for servo output and found 9v!
    Carver, MA
    196
    Default
    LM4558 pin #8
    4066 pin #14
    555 pin #4 and 8
    LM4558 pin #4
    555 pin 1
    Got it! Looks like the ground to the 3rd pin for servo output wasnt quite right. Thank u sooo much!! I'll send u a pic when its up an running.
    Also can I submit a mirror image of board layout for ur wiki? I think having to reverse what I'm looking at to wire it caused the mistake. As soon as I was looking at the mirror image it became clear.
    Carver, MA
    196
    Here's a picture of the servo board (mirror image), as you would view it from the back for wiring purposes.
    Nov 2008
    Peru, Indiana
    525
    I'm. Glad to hear you got it working
    May 2013
    1
    Does anyone know what happened to the scary terry boards or did anyone end up making a group of these up ?
    Carver, MA
    196
    I ended up making mine from a breadboard. It worked the first year but since then has not worked right. I would be interested in getting one of these made-up as well.
