Results 1 to 10 of 19
Thread: Channel extent of Vixen 3.0
    Brownsville, TX
    1,178
    Default Channel extent of Vixen 3.0
    Just out of curiosity what is the extent of channels that Vixen 3.0 could handle? I think that Vixen 2.1 and 2.5 could handle up to 9,999 channels. With the advent of RGB controllers and strings I just wondered if Vixen 3.0 could handle say 32K channels?
    2010 Plan: Hoping to maybe break the 100 channel marker.
    2011 Plan: Finally hitting 116 channels!
    1,744
    Default Re: Channel extent of Vixen 3.0
    Quote Originally Posted by Penfold View Post
    I think the 2.x limit is actually higher than that, at least for some functions.
    don
    Click for display details >>
    Eagan, Mn.
    1,513
    I believe the beta was one more digit 99,999. But the final release?
    Canberra, ACT, Australia
    600
    I haven't created more than 2k RGB channels in Vix3 at this time due more to the UI slowness as node counts go up but suspect the limit will be far above what even the extreme guys want.
    As for 2.x, at least in 2.5 the limit is certainly above 9999 as I just created a 12k, 25ms channel sequence a minute long and filled it using the random function and then played the sequence, no output plugins configured though.
    Cheers
    2012:
    Software: LightFactory Personal
    Hardware: J1Sys Pixel controllers . Http://www.j1sys.com
    Lights: 6000+ Pixels and 20k+ LEDs
    Channels: around 20,000 channels
    You know where to find me....
    Oct 2007
    Bundanoon NSW Australia
    185
    Vixen 2.x allows the creation of +10k channel counts. The problem arrises when you go to assign start channels to the controllers you are using. It is these data entry fields that limit you to four digits. The workaround is to manually edit the vixen file to set the correct channel number. This issue was highlighted on one of Ed's Ethcongateway tutorials.
    Spokane, WA, USA
    684
    Since 3.0 is doing a lot more in a much more complex fashion (not just zipping single byte values around), it's going to be inherently slower in producing results. However, we're working out a caching mechanism to help counter that. Additionally, there could be some facility for compilation and playback that would render everything into simple byte values that later gets read and executed.
    Additionally, your hardware will make a big difference. Faster CPU and more cores, of course, are going to improve performance.
    So, to actually answer your question, there won't be a set limit. The limits would be imposed by the hardware, but we're trying to make sure that single-core machines can still handle a pretty high channel count with a decent time resolution.
    600
    Quote Originally Posted by KC View Post
    KC
    Thanks for that, just a quick note, in all the playing i have done the UI slowness i refer to at least in the sequencer window appears to be tied to the application actually rendering the effect in the UI as once it has rendered it once moving around the sequence time wise is really fast and playback has not been an issue
    Cheers
    2012:
    Brownsville, TX
    1,178
    Thanks KC for the update!
    1,744
    Sounds a lot like Vixen 2.x.
    don
    Spokane, WA, USA
    684
    don
    That's been one point of question -- do we do it as additional layers that eventually result in the same thing that 2.x was doing? Since we know that that's the simplest model and provides the greatest performance, it makes sense. But it also means that the data has to get into that state, and since we're no longer generating data in such a simple state, it has to be compiled or rendered down into that state. Now just how and when that's done...
