Results 1 to 6 of 6
Thread: How Test Supeflux LEDs without LED Tester
    Marietta, GA
    91
    Default How Test Supeflux LEDs without LED Tester
    I've got my FAST setups coming today and realized, doh!, forgot to order an LED tester...
    I thought I read in a post previously someone was using a modified computer supply for this (but couldn't find it), and was wondering specifically how you would do that (I have modified a computer power supply and can easily hook up +12, -12, +5, or +3.3).
    I was thinking of just applying 3.3V or 5V across + and - but worried I'm missing the obvious and might need a current limiting series resistor or something...
    My multimeter has a diode tester so was thinking I could use that as well...
    Other alternative is just build the boards and see
    Just trying not to reinvent the wheel.
    Thanks in advance!
    Default Re: How Test Supeflux LEDs without LED Tester
    Many (most?) multimeters have a diode check setting. That's what I use.
    7,868
    Default
    You don't want to connect directly to a power supply - it will smoke the LED. Use a watch cell battery and place the leads around the edges of it. It will take a bit of trial and error to find the correct orientation but once you do it goes quick.
    Brian
    Halloween in San Jose! - FB
    2013 Halloween Show - Homemade tombstones, Grave Crawler, 2x 3-axis skulls, 4x 1-axis skulls, Video Projection
    Holland, Manitoba
    281
    Quote Originally Posted by tfischer View Post
    +1 what he said. Just use your DMM on diode check. Quick and easy.
    Marietta, GA
    91
    thanks guys!
    Washington, Georgia
    2,376
    +1 On the watch battery. Get a CR2032, cheapest and easiest LED tester ever...
    DIYC Links:
    Christmas Wiki | Chat
    Ricky, Jrd
    2012
    Fm-02 + Wall Wart Tamer
    2 Simple Renard 32
    15 SSROZ
    Click here to show/hide my past display details ...
