Results 11 to 20 of 21
Thread: Nutcracker: new effect, meteors
    Littleton, Colorado
    2,555
    Default Re: Nutcracker: new effect, meteors
    Quote Originally Posted by tfischer View Post
    This looks very cool.
    I tried generating one, and got this error:
    Fatal error: Maximum execution time of 30 seconds exceeded in /users/meighan.net/htdocs/nutcracker/effects/read_file.php on line 46
    I tried it again and got this error:
    Internal Server Error
    The server encountered an internal error or misconfiguration and was unable to complete your request.
    Please contact the server administrator, your webmaster and inform them of the time the error occurred, and anything you might have done that may have caused the error.
    More information about this error may be available in the server error log.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    -Tim
    We will live with my 30 second resource limit on meighan.net , for the time being.
    This prompt
    How many meteors to launch each frame (1 to total pixels on your tree. Numbers ike 6-12 are reasonable.):
    Each frame, this many meteors will be randomly launched on your tree
    This directly increases the time of the effect generation. I use values 6-12 , and i fit.
    Also if your target tree has more pixels, it will take more time.
    I might suggest everyone have one target that is smaller, say 32x40 BOT/TOP and use that for trying effects. When you get what u like , just select your larger target and apply your effect to it.
    Sean
    Littleton, CO
    Latest releases [url]http://nutcracker123.com/nutcracker/releases[/url]
    xLights/Nutcracker Forum [url]http://nutcracker123.com/forum/index.php[/url]
    Facebook [url]https://www.facebook.com/groups/628061113896314[/url]
    [IMG]http://nutcracker123.com/nutcracker/images/ZZ_SEAN5.gif[/IMG]
    Dec 2010
    Murrieta, Ca
    554
    I'm sad that my model builds so quickly I guess that means I don't have enough pixels!
    5 houses using:
    Renard 64, 3 Ren24's, Ren8
    4 E682 pixel controllers
    2,300 WS2801 pixel nodes
    1200 dumb RGB
    Sequenced using LSP 2.5
    Nov 2009
    414
    Quote Originally Posted by Lefserev View Post
    Because I wasn't making a sequence. I think the server likes Iowans better because I haven't ran into any major problems yet.
    Hey I grew up in Iowa, that should count for something!
    Littleton, Colorado
    2,555
    Added one more option
    random_colours =1, then every pixel in the meteor is a different color
    random_colours=2, random color for the meteor, but the hue is kept the same
    any other value the the meteor will start with your start_color and finish with your end_color.
    here is random_colours=2
    _POST
    username f
    user_target ZZ_ZZ
    effect_class meteors
    effect_name METEOR4
    window_degrees 360
    start_color #FF1100
    end_color #380101
    frame_delay 11
    sparkles 5
    maxPhase 7
    seq_duration 5
    maxMeteors 3
    random_colours 2
    submit Submit Form to create your effect
    random_colours=1
    _POST
    username f
    user_target ZZ_ZZ
    effect_name METEOR5
    window_degrees 360
    start_color #FF1100
    end_color #380101
    frame_delay 11
    sparkles 5
    maxPhase 7
    seq_duration 5
    maxMeteors 3
    random_colours 1
    and finally any other number and we will look to start and end colors
    _POST
    username f
    user_target ZZ_ZZ
    effect_name METEOR6
    window_degrees 360
    start_color #FF1100
    end_color #380101
    frame_delay 11
    sparkles 5
    maxPhase 7
    seq_duration 5
    maxMeteors 3
    random_colours 0
    thanks
    Sean
    Littleton, CO
    Nov 2010
    Ennis TX
    229
    Sean having blast playing with this, just a few observations or misunderstandings on my end.
    Meteor effect seem to be downloading to vir files correctly.- Cool stuff.
    I am noticing txt routines do not appear to be accurate once converted into vixen preview.
    Gif preview appears normal for txt routines.
    Also all garland effects are downloading a blank vir for me, i also get the error,
    Warning: opendir(workspaces/klyneshouse) [function.opendir]: failed to open dir: No such file or directory in /users/meighan.net/htdocs/nutcracker/effects/make_vixen.php on line 202
    Also general question, seems that if editing existing effect of any type, and resubmitting, changes are not always made.
    Should one always rename existing and create new rather than trying to edit ?
    If so will a delete option be available ?
    Care Instructions: Never leave light set unattended while plugged in
    Nov 2010
    Ennis TX
    229
    deleted - duplicate post -
    Littleton, Colorado
    2,555
    Quote Originally Posted by klyneshouse View Post
    Ill have to check,
    This is a bug
    I get the same think
    Nutcracker: RGB Effects Builder for user
    On this page you create output files for the sequencers
    Calling read Target: Elapsed time = 0.00107 seconds
    Finished read Target: Elapsed time = 0.00112 seconds
    Finished filling dat_file_array: Elapsed time = 0.09073 seconds
    Limiting current sequences to 1000 frames
    11 seconds of animation with a 1 ms frame timing = 1000 frames of animation
    0 channels have been created for Vixen <= this should not be a zero.
    Click here for Vixen vir file. workspaces/2/ZZ_ZZ+GARLAND3.vir
    Click here for Vixen csv file. workspaces/2/ZZ_ZZ+GARLAND3.txt
    Total Elapsed time for this effect: Elapsed time = 16.39489 seconds
    I dont rename, and when i make a change it sticks. Steve gase also reported not having his changes made. Now, i do have fields that come back blank when i reclick. This is a bug i will fix
    Delete option (for targets, effects, gif files) is on my todo list
    See above
    Sean
    Littleton, CO
    Littleton, Colorado
    2,555
    I have fixed the garlands error of not producing a Vixen vir file.
    one down, one thousand to go
    Sean
    Littleton, CO
  9. #19
    5,302
    lol. The best part is your optomistic , great work with this sean. Just wish I knew how to use it .
  10. #20
    Elizabeth City, NC
    706
    Hey Sean,
    Been testing out Nutcracker and loving it so far... noticed that the vixen output files seem to be only working for the garland effect now.. just wanted to give you the heads up!!! Thanks!
    Quote Originally Posted by smeighan View Post
    [SIZE=3][B]8000 + E1.31 Channels (5x E68x controllers)
    128 Renard Channels[/SIZE][/B]
    sequencing with LightShow Pro 2.8 and/or Vixen 3 (using xLights scheduler)
    2 x Pixel Mega Trees, RGB Pixel Roofline, 2 x RGB Pixel Spinners, 11 x Pixel Bushes, 6 x GECE Icicle Arches, 16 x RGB Mini Trees, 2 x Vertical Pixel Poles,
    12 x 10w RGB Floods, 160 Strobes controlled by Arduino
    [URL="http://www.controlthelights.net"]http://www.controlthelights.net[/URL]
