Results 1 to 10 of 11
Thread: Vixen 2.1 Mega Tree RGB Profile maker
    Nov 2010
    Ponce, Puerto Rico
    141
    Post Vixen 2.1 Mega Tree RGB Profile maker
    Hi
    Since I saw the RGB sequencer idea of Sean, my interest for me trees started growing. One thing that came to my mind was, what was going to happen when he fisnishes his effects; I dont have profiles or adjustable previews for Mega Trees (never done a MT before). If you want a tree with 16 trings 42 pixels, 3 colors, the channel count grows quickly (2016 channels in this sample). Its not an easy task to create 2016 channels on Vixen by hand.
    For this reason I created a small tool that will create a profile and a Matrix Adjustable preview for your new MT. The output of the tool is an XML Vixen profile (*.pro)
    It has an input for number of strings and number of pixels by string. A selection for the type of construction: Bottom to Top, Up/Down - Next and Up/Down -180.
    Its a work in progress tool. http://dl.dropbox.com/u/6288290/VixenRGBProfiler.zip
    Comments/Suggestions?
    Orchard Park, New York
    281
    Default Re: Vixen 2.1 Mega Tree RGB Profile maker
    Very helpful, thank you!
    7,774
    Excellent tool - nice and simple to use - one question though - where were you last year?!
    You can have multiple adjustable windows per profile/sequence so this can be a quick way to display your tree as well as the rest of your setup.
    Brian
    Halloween in San Jose! - FB
    Elizabeth City, NC
    428
    thanks for making this! works great!!
    3750 + E1.31 Channels (3x E681)
    128 Renard Channels
    sequencing with LightShow Pro 2.5
    640 Pixel Mega Tree w/ RGB Star, RGB Pixel Roofline, 6 x GECE Icicle Arches, 8 x RGB Mini Trees, 2 x Vertical Pixel Poles, 10 x FAST + more
    Nov 2010
    Ennis TX
    143
    Awesome time saver - thanks for the tool.
    How hard would it be to define the start channel of the mega tree to paste this into existing profiles ?
    For instance if my tree started on channel 1000.
    Or is there another short cut I am missing to sync it up to existing profiles ?
    Care Instructions: Never leave light set unattended while plugged in
    Nov 2010
    Ponce, Puerto Rico
    141
    Default
    Learning C#... and working off-shore.
    RGB Mega Tree Plugin: www.emmanuelmiranda.info
    1,500
    Will it work in V v2.5?
    Thx.
    \dmc
    ________________________
    Nov 2010
    Ponce, Puerto Rico
    141
    Quote Originally Posted by dmcole View Post
    Thx.
    \dmc
    Not sure, I will need to review a 2.5 profile and see if its the same as in 2.1. Will let you know later.
    Nov 2010
    Ponce, Puerto Rico
    141
    Post Re: Vixen 2.1 Mega Tree RGB Profile maker
    I have released a new version with some of the suggestions. Now it generates for Vixen 2.5 and you can enter the starting channel number (still in testing).
    Thx.
    \dmc
    I have added a select box to generate the correct file for each version.
    Quote Originally Posted by klyneshouse View Post
    I added an extra input field for the starting channel. This is still on testing. Looks like there is some issues if you try to import as it is to Vixen, but the intended purpose is to copy/paste into your existing profile XML.
    1,500
    Quote Originally Posted by nuelemma View Post
    Wow! I won't have a chance to try this out before the weekend, but thanks in advance!
    \dmc
