Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Your Opinion - Arch - 8 or 9 Channels
    Nov 2010
    Placerville, CA
    1,811
    Default Re: Your Opinion - Arch - 8 or 9 Channels
    There you go- with an arch, you will tend to trigger a sweep (or other effect) on a beat and let it end (closely as possible) on some other beat. Kinda like swinging your arms in the air, like you just don't care...
    IMHO, we are making this discussion WAY too complex.
    The bottom line for me is that YOU have to physically build the arch, and I believe that is the starting point. How big do I want them? What diameter size PVC? What is the length of the light strings I am placing on them, and how many "inches wrapped" does that equate to? Am I even going to use PVC? Do I want it modular for easy storage? Do I want permanently shaped PVC because I have unlimited storage?
    For example, you determine that you want an arch that is 9 feet long and 3 feet high ... you are going to need 12 feet of PVC. Your 100ct lights when wrapped cover 18" of PVC, and BAM!!! Based on this, you have an 8 channel arch. You want smaller ones? Use 50ct lights or accept less segments... Your using LED strip you say? Even easier, you can just cut it every 5 or 10 cm for low or high density strips, respectively.
    There are enough factors to determine without getting into beats or sequencing. We all probably understand that in general, the more segments there are, the smoother the effect will be. The musical aspects of beats per measure, etc. do "lend" themselves to certain "optimal" segment counts, but it is not definitive. The contoller outputs also somewhat "lend" themselves to certain "optimal" segment counts, but it is not definitive either. Sequencing is sequencing. It's not fun or sexy ... just make it work.
    SEMPER LENTESCO ... At the end of the day, everyone will look across the street and say, "WOW, those lights are amazing!!!!" Not, "I am dissapointed that Mr. Umpty-fratz didn't use 9 channels on those archs. Pitiful and a disgrace to Christmas."
    http://www.vixenlights.com/sig/sig_h.php/320/All.gif
    Taking a Hiatus, but still in lurking status ... ;)
    Treasure Valley, Idaho
    2,314
    Rofl............
    Quote Originally Posted by imperialkid View Post
    semper lentesco ... At the end of the day, everyone will look across the street and say, "wow, those lights are amazing!!!!" not, "i am dissapointed that mr. Umpty-fratz didn't use 9 channels on those archs. Pitiful and a disgrace to christmas."
    Key West, FL
    1,493
    I'm actually going to build a arch-fan combo. I am looking to see if I keep the Fan structure whole or break it in the middle.
    9 segments will span the break while 8 meet it.
    I still like 9 - so that is what I will most likely do.
    Thanks for all of your comments.
    Joe
    Nov 2010
    Goodrich, Michigan
    382
    First year was 2011, I used 8. Some songs i used the top two segments together as if they were one, effectively making it a seven segment arch.
    I don't think anyone else will notice, 7, 8 or 9.
    Eagan, Mn.
    1,515
    Joe
    I've seen several fan's that fold in the middle and some that arches fold with it and some that the arches come off the fan.
    So your options are still open.
    Brian
    Nov 2010
    Placerville, CA
    1,811
    And it is really bad when the arch hits the fan- arch EVERYWHERE... ;-)
    7,788
    I used 9 for a very simple reason - - the 70-count LED strings are a bit shorter than 100-count incans and 9 fills a 10' section of 3/4" PVC just right... Each arch has a bell hiding the 12-channel SSR in a CG-1000 box so I use 10 channels and 2 for spares on each arch - these have come in quite handy at times.
    Brian
    Halloween in San Jose! - FB
    Just south of Portland Oregon
    794
    I had the same debate. Went with 8, very happy I did. Two SSR's per arch and easy to sequence. my 2¥.
    Anybody use an IPad? Where is the dang cents key?
    Nov 2010
    Ponce, Puerto Rico
    141
    Default
    Quote Originally Posted by Greg in Canby View Post
    Press and hold the $ sign button, you should get a list of additional symbols.
    RGB Mega Tree Plugin: www.varaderolights.com
