Thread: HLS Mega-Tree Tip
    Key West, FL
    1,491
    Default HLS Mega-Tree Tip
    As I'm using my tool, I came up with a nice tip I will share with anyone playing with HLS.
    It will reduce the number of sequence channels by 2/3 if you are working with a multicolored object.
    Example - 16 channel mega-tree - three colors (actual colors don't matter - so lets say orange, gray, and aqua). You'll see why I chose off colors in a minute.
    Normally you would have 16 channels of orange, 16 channels of gray, and 16 channels of aqua to edit in the sequencer.
    We reduce that by 2/3 by using the RGB capability in HLS in an non-standard manner.
    Background: RGB was originally put in place to address dumb RGB led strings (string has only one color displayed at a time).
    In the HLS editor, you select the color you want the string to have (working with a single channel) and HLS converts that color into three individual channels sent to your controller --- usually Red, Green, Blue channels - but they can be to anything.
    So - I create 16 RGB channels in HLS to do my mega-tree.
    Mentally - or put on a cheat sheet on the monitor - the following association: Red=Orange, Green=Gray, and Blue=Aqua. If I design my sequence now just using the RGB colors - the intensity data will be directed to my physical Orange, Gray, and Aqua LED strings.
    If I want more than one of my led color strings on at the same time - select the RGB color that has them both at 100%. Example - if I wanted my Orange and Gray lights on 100% at the same time - I would simply select RGB color YELLOW (yellow is 100% red and 100% green). If I wanted all led strings (all colors) on at the same time - I would select RGB color White - since white is 100% red, 100% green, and 100% Blue.
    So I'm designing my 16 channel - three color Mega-Tree using only 16 channels and encoding what actual color is being lite by the RGB color I have selected.
    I can still do ramps, fades, etc. I can actually do a RGB color shift over time and the results will be a two or three of my lights on (different intensities) some going to fade to black, others going to ramp up intensity.
    I picked odd colors for the led string because I did not want you to start associating string color to RGB color.
    I am also NOT trying to produce multiple colors by use the RGB capability - just a method to reduce channel count in the sequence editor.
    I hope I made this tip clearer than mud.
    Joe
    Vancouver B.C Canada
    1,309
    Default Re: HLS Mega-Tree Tip
    Joe
    Would You be able to add a color pallet to the sequence editor , like say when you click on a channels effect and choose modify , could a selectable color pallet
    be incorporated there ? Just a thought , maybe it could be triggered active if rgb is selected under channel management .
    Key West, FL
    1,491
    The Color Pallet is there and available for a channel identified as RGB.
    That's how I selected RED, GREEN, and BLUE effects for the RGB channel (last one)
    Joe
