Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: WS2811 pixel compatibility
    5,687
    Default Re: WS2811 pixel compatibility
    Great news Jim , will the dithering to achieve 8-bit dimming with the 6803 pixels be auto set when 6803 is selected as pixel type ?
    1,216
    Yes, right now it happens automatically as long as the string length is 55 or less. Longer than that and the flickering from the dithering becomes visible, so dithering is turned off for longer strings. At some point I may make it a configuration option.
    The Sandevices E680/E681/E682 Pixel Controllers, part of the[SIZE=3] [COLOR=red]P[/COLOR][COLOR=orange]I[/COLOR][COLOR=blue]X[/COLOR][COLOR=lime]E[/COLOR][COLOR=magenta]L[/COLOR] [COLOR=red]P[/COLOR][COLOR=lime]R[/COLOR][COLOR=blue]O[/COLOR][COLOR=red]J[/COLOR][COLOR=magenta]E[/COLOR][COLOR=cyan]C[/COLOR][COLOR=red]T[/COLOR]
    [URL="http://www.sandevices.com"]www.sandevices.com[/URL][/SIZE] <-email jim at
    Sep 2008
    Baulkham Hills, NSW
    2,605
    Jim,
    when I load 2.025 I an unable to get to the web page. Before I get the Laptop out, does the new firmware changed the stored Static IP ADdress? When I re-load the 2.023 firmware, My old static IP address works again.
    1,216
    No the configuration should not change. Make sure you load the correct one for your hardware (E680 or E681).
    Sep 2008
    Baulkham Hills, NSW
    2,605
    Quote Originally Posted by jstjohnz View Post
    That is embarassing. All fixed.
    [B][I]Matt[/I][/B]
    Nov 2010
    Placerville, CA
    2,199
    The .eeprom file I believe is a byte-for-byte image of what's to be written to the first 32KB of the eeprom. The file, therefore, is exactly 32K bytes long. I should have the utility available for download soon that allows you to send the .eeprom file to the controller via the lan connection, so no programmer required when doing it that way.
    I have a pre-down-the-wire prom that I have to update to even be able to even do the down the wire update.
    [I][SIZE=2]"Beam me up Scotty, there are only limited pockets of intelligent life on this planet!!"[/SIZE][/I]
