Results 1 to 10 of 16
Thread: Wire alternavite to cat%
    Hawthorn Woods, IL
    545
    Default Wire alternavite to cat%
    :?: Has anyone tried to use 4 pair wire such as intercom cable or telephone wire, in place of cat cable to interface with SSRs? If so, has it worked. As it is not data sensitive, I thought it would work. The pricing is generally 1/2 that of Cat
    Central Florida
    259
    Default
    Can you give us a link to it somewhere?
    "A polar bear is just a rectangular bear after a coordinate transform"
    http://www.christmasinshirley.com/fo...inch64_128.jpghttp://www.christmasinshirley.com/fo...logosm_202.gif
    Powder Springs, GA
    1,028
    Default
    I think there are quite a few that use 4 pair wire.
    If you are not a supporting member please consider Becoming an Active Member
    1,500
    Default
    Wireway on eBay (http://stores.ebay.com/eWireway) sells 500 ft. of telephone wire (Cat3) for $35 and 500 ft of Cat5 for $36. Sevenish cents a foot either way.
    Of course, if you want to buy the 45 case-skid of 1000-ft cases of Cat5 (any color BTW), you can drive the cost down to a nickle about a foot, but even for the most dedicated blinky flashy that might be a bit too much Cat5.
    \dmc
    PS: Not affiliated with Wireway; just did a search.
    cmurray Guest
    Default
    I use flat satin phone cord.
    6 conductor rj12 connectors.
    No issues.
    Joel
    Hawthorn Woods, IL
    545
    Default Thanks to All
    Just looking for some reassureance. Seven cent a foot is good for me.
    WI
    2,526
    Default
    If all you are doing is running SSRs 4 pair cat 3 will be fine. If however you were running high speed data down the wire cat5 or higher would be required. Go for it.
    Hawthorn Woods, IL
    545
    Default
    Data from the PC will be on good wire. I was talking about the long runs to the SSRs.
    WI
    2,526
    Default
    That will work fine then.
    Broken Arrow, Oklahoma
    414
    Default
    The funny thing is that I found Cat3 cable to be more expensive than cat5. So guess what I used.
