Page 20 of 24 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 238
Thread: HLS Sequencer - Beta - Free to use
  1. #191
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Default Re: HLS Sequencer - Beta - Free to use
    I have RPM's Enttech Pro clone and an Enttec Open. I am willing to try them out to help the widder community. it will aslo let me a good go with HLS.
    Check it out here
  2. #192
    Sep 2008
    Baulkham Hills, NSW
    2,241
    I tried converting my MP3s to Wav using Audacity. When I load the resultant WAV file I get the following error.
  3. #193
    Key West, FL
    1,493
    Matt:
    I have not run into that CHUNK before.
    I will release 4C shortly that will bypass that chunk - see if the song plays correctly.
    Give me an hour or two.
    Joe
  4. #194
    Key West, FL
    1,493
    Matt:
    Version 4C is available - it ignores unwanted CHUNK blocks.
    Joe
  5. #195
    Tustin, CA
    1,134
    Just a thought,
    Unless I've just missed it HLS doesn't have much of a visualizer compared to say LOR's S3. Well as much as LOR might not like the idea why not program HLS to be able to talk to LOR Visualizer? LOR Visualizer is commanded by LOR S3 using IP protocol so once one figures out the commands sent from the sequencer to the visualizer it should be easy for HLS to talk to the visualizer as well. I really like the idea of the visualizer being a totally separate program as well as the thought of others writing visualizers that communicate using the same protocol.
    Anyway, as I said just a thought.
    If I get some time I'll try capturing a few frames just to see what it looks like.
  6. #196
    Vancouver B.C Canada
    1,309
    Would some one with entec pro >clone coding be so kind as to help Joe get the usb >dmx supported.
    thanks.
  7. #197
    Sep 2008
    Baulkham Hills, NSW
    2,241
    Joe
    That did the trick. I can import my own converted music. Thanks.
    I can also assist with debugging the Entech Pro Output. (I have one on my desk permanently.
    Check it out here
  8. #198
    Key West, FL
    1,493
    When you use Enttech's or RPM's USB to DMX dongle - are they set up as a virtual COM port?
    Or do they need direct FTDX22 communication?
    Thanks.
    Joe
  9. #199
    hello Joe,
    I think I might know who can answer your Entec/Dongle questions. Let me ping him to see what he says.
    Jess
  10. #200
    7,789
    RPM's dongle comes up as a virtual COM port and you assign the Enttec Pro (in Vixen) to that COM port - the baud settings are not used since it uses 250Kbps by default.
    Brian
    Halloween in San Jose! - FB
