So how much of MS API's are you using and are they scattered throughout the code or centralized in your own functions? If you used only a small set of API's I'm guessing an experienced programmer on both platforms could convert it fairly quickly. If you centralized the API calls in your own functions it would be even quicker. If you used DLL then it gets harder.
Anyway one can only dream![]()
I use MFC - Microsoft Foundation Classes - this provides the Windowing capability - the Visual part of VC++.
Joe
I have added another feature to PixelPlane effects - you can now slow them down.
You can run them at Full Speed, Half Speed, Third Speed, or Quarter Speed.
Joe
Just got my first Vixen import to HLS and converted to RGB matches exactly. This is really getting exciting now. Have got preview running of the sequence and just starting the output configuration.
Anyone who has not tried it is missing an amazing tool.
Thanks Joe.
Al
When might we see a LOR S2/S3 import for those of us that don't run Vixen?
Also, have you seen a problem where the menu names don't display but the menu items do? I'm guessing I have a possible Parallels issue but those are rare.
John
John:
I've got two people beating HLS to death. No issues at this time.
The only issue with a LOR import is that LOR can use internal controller effects.
Please supply me with a file so I can look at it.
Joe
Got my output method setup and looks to be working. Going to set up lights tommorrow for blinky flashy.
Al
I've upgraded HLS to accept 30,000 channels.
Joe
Let's see... if I get started building my SSRs now, and I built 10 a day, I could be done with that in June, 2014. Then I'll start working on my sequencing and think I can finish that by... ohhhh.... 2017. But my real question is, where's a good cheap place to get about 20 miles of cat5?
Awesome, Joe. Just awesome!
dirknerkle
