Page 16 of 24 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 238
Thread: HLS Sequencer - Beta - Free to use
  1. #151
    Jan 2009
    California
    303
    Default Re: HLS Sequencer - Beta - Free to use
    I am not sure if I found a bug or not. When playing in preview using play button screen goes from background image to lite display and works. If I set a play from mark the preview of the background image does not go out and the lite display does not move.
    One other thing at some point in the sequence the display lites stop responding to channel info. There is data on channels when switching back to channel view.
    Al
  2. #152
    Key West, FL
    1,493
    Quote Originally Posted by intwoit2002 View Post
    Al
    Congrats - you found a bug.
    I had not tested preview from a mark.
    Version 1R fixes it.
    Link to my DownLoad Site: http://www.joehinkle.com/HLS
  3. #153
    Aug 2007
    Medford, ny
    614
    I know i asked about this effect but would it be hard for you to add effects as group as an option? so if i wanted to add a chase or level quickly instead going 500 channels down. Thx
  4. #154
    Key West, FL
    1,493
    Quote Originally Posted by boarder3 View Post
    Your request sounds like a capability from Vixen 3.
    I'm not designed to provide that.
    Joe
  5. #155
    Aug 2007
    Medford, ny
    614
    Ok thx I use lsp and vixen and tried madrix figured i tell you some of there best features and carry them into yours. But cant have everything anyway love the software so far.
  6. #156
    Key West, FL
    1,493
    I have released Version 1S
    I have added Mouse Wheel scrolling to the Preview Screen - so the Mouse Wheel AND Up/Down arrow keys will changed the active channel in Preview.
    I have also added an Audio Looping capability - the sequence will continuously loop between two points until halted.
    Set you normal "Play Start" point by Right Clicking on the Audio Ruler. Place the END Loop point by Holding down the CTRL Key and Right Mouse Clicking on the Audio Ruler (You will see a GREEN Loop End Flag).
    When you click - "Play from Mark" - the sequence and audio will loop between the two points.
    Enjoy.
    Joe
  7. #157
    Vancouver B.C Canada
    1,309
    Thanks Joe for adding scrubbing , this will help alot .
    Cheers
    Richard
    Btw is dmx A possibility
  8. #158
    1,309
    Is there any 1 with a 48lsd and break out boards testing this software ?
    Could you post your results .
    Richard
  9. #159
    Key West, FL
    1,493
    I have implemented what I call PixelPlane capability into HLS.
    You identify the number of pixels you want to control. It is up to you to set the Universe Number and Channel number to match your hardware.
    Nutcracker will export a HLS formatted file that can be then positioned within your sequence.
    In the Sequence Editor - you see only a Single Channel that represents your PixelPlane so you are not burdened with a lot of channels.
    HLS will only output your PixelPlane data - which means it is not viewable in Preview Mode.
    If anyone is interested - let me know and I will make a video on how to use the feature.
    The Nutcracker format is very simple so if you want to generate Pixel effects outside of Nutcracker and display them --- that's also possible
    HLS Version 2C incorporates the capability.
    Joe
  10. #160
    Key West, FL
    1,493
    I added RDS support a while back - but did not let the group know.
    When you tell HLS that you want to export a sequence for the player - you set the RDS information.
    Joe
