Code:
#define XMAS_PIN 8
#define xmas_color_t uint16_t
#define XMAS_LIGHT_COUNT (36)
#define XMAS_GROUP_COUNT (3)
#define XMAS_GROUP_LIGHT_COUNT (12)
#define XMAS_CHANNEL_MAX (0xF)
#define XMAS_DEFAULT_INTENSITY (0xCC)
#define XMAS_COLOR(r,g,b) ((r)+((g)<<4)+((b)<<8))
#define XMAS_COLOR_WHITE XMAS_COLOR(XMAS_CHANNEL_MAX,XMAS_CHANNEL_MAX,XMAS_CHANNEL_MAX)
#define XMAS_COLOR_BLACK XMAS_COLOR(0,0,0)
#define XMAS_COLOR_BLUE XMAS_COLOR(0,0,XMAS_CHANNEL_MAX)
bool sync;
void xmas_begin(uint8_t pin);
void xmas_one(uint8_t pin);
void xmas_zero(uint8_t pin);
void xmas_end(uint8_t pin);
digitalWrite(pin,1);
delayMicroseconds(7);
digitalWrite(pin,0);
delayMicroseconds(11); //This results in a 20 uS long low
delayMicroseconds(2);
delayMicroseconds(20-3);
delayMicroseconds(40); // Can be made shorter
void xmas_set_color(uint8_t led,uint8_t intensity,xmas_color_t color, uint8_t pin)
uint8_t i;
cli(); //Disable interrupts while we write to GECEs
xmas_begin(pin);
//6-Bit bulb address (MSB first)
for(i=6;i;i--,(led<<=1))
if(led&(1<<5))
xmas_one(pin);
else
xmas_zero(pin);
//8-Bit brightness (MSB first)
for(i=8;i;i--,(intensity<<=1))
if(intensity&(1<<7))
xmas_one(pin);
else
xmas_zero(pin);
//12 bit Color (Blue, Green, Red) (MSB first)
for(i=12;i;i--,(color<<=1))
if(color&(1<<11))
xmas_one(pin);
else
xmas_zero(pin);
xmas_end(pin);
sei(); //Re-enable interrupts now that we're done writing to GECEs
void xmas_set_group_address(uint8_t pin)
for (int i = 0; i < XMAS_GROUP_COUNT; ++i)
for (int k = 0; k < XMAS_GROUP_LIGHT_COUNT; ++k)
xmas_set_color(k,XMAS_DEFAULT_INTENSITY,XMAS_COLOR_BLACK,pin);
void xmas_set_all_one_address(uint8_t pin)
for (int i = 0; i < XMAS_LIGHT_COUNT; ++i)
xmas_set_color(0,XMAS_DEFAULT_INTENSITY,XMAS_COLOR_BLACK,pin);
void setup()
delay(10);
Serial.begin(57600);
delay(10);
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
pinMode(XMAS_PIN, OUTPUT);
digitalWrite(XMAS_PIN, 0);
xmas_set_group_address(XMAS_PIN);
sync = false;
void wait_for_serial()
while ( ! Serial.available() > 0 ) { }
int renardReadBytes( uint8_t *bytes, uint8_t bytes_size )
int in_byte = 0;
int bytes_read;
for ( bytes_read = 0; bytes_read < bytes_size; )
wait_for_serial();
in_byte = Serial.read();
switch (in_byte)
case(0x7E): // We saw the sync byte, start over!
sync = true;
return bytes_read;
case(0x7D): // Skip the pad byte
continue;
case(0x7F): // Escape character, we need to read one more byte to get our actual data
wait_for_serial();
switch (in_byte)
case(0x2F): // renard wants an 0x7D
in_byte = 0x7D;
case(0x30): // renard wants an 0x7E
in_byte = 0x7E;
case(0x31): // renard wants an 0x7F
in_byte = 0x7F;
bytes[bytes_read++] = in_byte;
return bytes_read;
int renardRead( uint8_t *bytes, uint8_t byte_count )
int in_byte = 0;
while ( ! sync )
wait_for_serial();
if ( in_byte == 0x7E ) // Sync byte signifies start of packet
sync = true;
if ( sync )
sync = false;
wait_for_serial();
if ( in_byte == 0x80 ) // Read from here
return renardReadBytes(bytes, byte_count);
return 0;
void loop()
int nbr_bytes = XMAS_GROUP_LIGHT_COUNT * 4;
uint8_t bytes[nbr_bytes], bytes_read;
bytes_read = renardRead(&bytes[0], nbr_bytes);
if ( bytes_read == nbr_bytes )
// We have now received 4 bytes of data per string, do something with them!
uint8_t red;
uint8_t green;
uint8_t blue;
uint8_t white;
int b = 0;
for (int i=0; i < XMAS_GROUP_LIGHT_COUNT; ++i)
red = bytes[b];
b++;
green = bytes[b];
b++;
blue = bytes[b];
b++;
white = bytes[b];
b++;
red = ( red+(white/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red+(white/3) );
green = ( green+(white/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green+(white/3) );
blue = ( blue+(white/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue+(white/3) );
xmas_set_color(i,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red>>4),(green>>4),(blue>>4)),XMAS_PIN);
