Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: Custom Arduino-based Renard-to-GECE controller (codename horae)
    Default Re: Custom Arduino-based Renard-to-GECE controller (codename horae)
    Quote Originally Posted by chesterspot View Post
    Yes, I sent him ColorNodeV1.0Gerbers.zip. He said that it had been a popular board design for a while so he had in stock vs having to wait for them. Reasonable pricing, high quality boards, good service.
    I have already started a new design better than the color node. Enumeration will be a issue with his design due to a flaw upon a power outage and resets. The Coordinator is limited to just set types of sequences. No true control of the lights from vixen and will be limited in the vixen 3.0
    Sep 2010
    Clear Lake, TX
    211
    My plan was to use MaterDaddy's code. I just wanted a board that would fit in the original enclosure. When you're ready to test let me know, Ill help.
    Well done! You will become the WiznetWizard!
    Level UP!
    Sep 2010
    Clear Lake, TX
    211
    Default
    @roboengr
    How is this progressing? Do you have any semi-useful code yet? I've got time this weekend to play.
    Sent from my Desire HD using Tapatalk 2
    Level UP!
    Sep 2010
    Clear Lake, TX
    211
    @materdaddy
    Well I brought my GECE's and arduino to work to play with at lunch. And it's a success. I'm going to work on modifying your code to try and talk to the pixels individually unless roboengr has an update.
    Level UP!
    Dec 2010
    Oceanside, CA
    2,068
    Awesome! Glad to hear it. If you have any questions or anything let me know!
    The perfect is the enemy of the good. -Voltaire
    Sep 2010
    Clear Lake, TX
    211
    Default
    Hopefully ill have something tomorrow. I'm going to use groups to keep the pixel count low for starters.
    Level UP!
    Sep 2010
    Clear Lake, TX
    211
    Default
    BTW, its hard to get work done with those lights just blinking away on my desk. :D
    Level UP!
    Sep 2010
    Clear Lake, TX
    211
    Grouping works great! I added two variables XMAS_GROUP_COUNT and XMAS_GROUP_LIGHT_COUNT to loop through the enumeration. I also want to use this to loop through setting the color but I'll have to refer to you true software guys. How do I get a variable like red_ + i to work? I want to only want to have to code xmas_set_color once and then run through a loop for each group. In the code you'll see where I copy and pasted the code six times (group of 6 nodes). I want to be able to have the variables show red0, blue0, green0 but in the loop so something like red + i which would work in VB but not in C/Arduino IDE. I've learned C and Java this past year but just enough to be dangerous. Below is the code. Thanks materdaddy and darco for laying the ground work. I'll post a video later today.
    Loop idea:
    for (i=0; i < XMAS_GROUP_LIGHT_COUNT; ++i)
    red+i = ( red+i+(white+i/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red+i+(white+i/3) );
    green+i = ( green+i+(white+i/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green+i+(white+i/3) );
    blue+i = ( blue+i+(white+i/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue+i+(white+i/3) );
    xmas_set_color(i,XMAS_DEFAULT_INTENSITY,XMAS_COLOR ((red+i>>4),(green+i>>4),(blue+i>>4)),XMAS_PIN);
    Code:
    #define XMAS_PIN 8
    #define xmas_color_t uint16_t
    #define XMAS_LIGHT_COUNT    (36)
    #define XMAS_GROUP_COUNT    (6)
    #define XMAS_GROUP_LIGHT_COUNT    (6)
    #define XMAS_CHANNEL_MAX          (0xF)
    #define XMAS_DEFAULT_INTENSITY     (0xCC)
    #define XMAS_COLOR(r,g,b)     ((r)+((g)<<4)+((b)<<8))
    #define XMAS_COLOR_WHITE     XMAS_COLOR(XMAS_CHANNEL_MAX,XMAS_CHANNEL_MAX,XMAS_CHANNEL_MAX)
    #define XMAS_COLOR_BLACK     XMAS_COLOR(0,0,0)
    #define XMAS_COLOR_BLUE     XMAS_COLOR(0,0,XMAS_CHANNEL_MAX)
    bool sync;
    void xmas_begin(uint8_t pin);
    void xmas_one(uint8_t pin);
    void xmas_zero(uint8_t pin);
    void xmas_end(uint8_t pin);
      digitalWrite(pin,1);
      delayMicroseconds(7);
      digitalWrite(pin,0);
      delayMicroseconds(11); //This results in a 20 uS long low
      delayMicroseconds(2);
      delayMicroseconds(20-3);
      delayMicroseconds(40); // Can be made shorter
    void xmas_set_color(uint8_t led,uint8_t intensity,xmas_color_t color, uint8_t pin)
      uint8_t i;
      cli(); //Disable interrupts while we write to GECEs
      xmas_begin(pin);
      //6-Bit bulb address (MSB first)
      for(i=6;i;i--,(led<<=1))
        if(led&(1<<5))
          xmas_one(pin);
        else
          xmas_zero(pin);
      //8-Bit brightness (MSB first)
      for(i=8;i;i--,(intensity<<=1))
        if(intensity&(1<<7))
          xmas_one(pin);
        else
          xmas_zero(pin);
      //12 bit Color (Blue, Green, Red) (MSB first)
      for(i=12;i;i--,(color<<=1))
        if(color&(1<<11))
          xmas_one(pin);
        else
          xmas_zero(pin);
      xmas_end(pin);
      sei(); //Re-enable interrupts now that we're done writing to GECEs
    void xmas_set_group_address(uint8_t pin)
      for (int i = 0; i < XMAS_GROUP_COUNT; ++i)
        for (int k = 0; k < XMAS_GROUP_LIGHT_COUNT; ++k)
         xmas_set_color(k,XMAS_DEFAULT_INTENSITY,XMAS_COLOR_BLACK,pin);
    void xmas_set_all_one_address(uint8_t pin)
      for (int i = 0; i < XMAS_LIGHT_COUNT; ++i)
        xmas_set_color(0,XMAS_DEFAULT_INTENSITY,XMAS_COLOR_BLACK,pin);
    void setup()
      delay(10);
      Serial.begin(57600);
      delay(10);
      pinMode(5, OUTPUT);
      digitalWrite(5, LOW);
      pinMode(XMAS_PIN, OUTPUT);
      digitalWrite(XMAS_PIN, 0);
      xmas_set_group_address(XMAS_PIN);
      sync = false;
    void wait_for_serial()
        while ( ! Serial.available() > 0 ) { }
    int renardReadBytes( uint8_t *bytes, uint8_t bytes_size )
      int in_byte = 0;
      int bytes_read;
      for ( bytes_read = 0; bytes_read < bytes_size; )
        wait_for_serial();
        in_byte = Serial.read();
        switch (in_byte)
          case(0x7E): // We saw the sync byte, start over!
            sync = true;
            return bytes_read;
          case(0x7D): // Skip the pad byte
            continue;
          case(0x7F): // Escape character, we need to read one more byte to get our actual data
            wait_for_serial();
            switch (in_byte)
                case(0x2F): // renard wants an 0x7D
                  in_byte = 0x7D;
                case(0x30): // renard wants an 0x7E
                  in_byte = 0x7E;
                case(0x31): // renard wants an 0x7F
                  in_byte = 0x7F;
        bytes[bytes_read++] = in_byte;
      return bytes_read;
    int renardRead( uint8_t *bytes, uint8_t byte_count )
      int in_byte = 0;
      while ( ! sync )
        wait_for_serial();
        if ( in_byte == 0x7E ) // Sync byte signifies start of packet
          sync = true;
      if ( sync )
        sync = false;
        wait_for_serial();
        if ( in_byte == 0x80 ) // Read from here
          return renardReadBytes(bytes, byte_count);
      return 0;
    void loop()
      //int nbr_bytes = XMAS_GROUP_LIGHT_COUNT * 4;
      uint8_t bytes[24], bytes_read;
      bytes_read = renardRead(&bytes[0], 24);
      if ( bytes_read == 24 )
        // We have now received 4 bytes of data per string, do something with them!
          uint8_t red0 = bytes[0];
          uint8_t green0 = bytes[1];
          uint8_t blue0  = bytes[2];
          uint8_t white0  = bytes[3];
          uint8_t red1 = bytes[4];
          uint8_t green1 = bytes[5];
          uint8_t blue1  = bytes[6];
          uint8_t white1  = bytes[7];
          uint8_t red2 = bytes[8];
          uint8_t green2 = bytes[9];
          uint8_t blue2  = bytes[10];
          uint8_t white2  = bytes[11];
          uint8_t red3 = bytes[12];
          uint8_t green3 = bytes[13];
          uint8_t blue3  = bytes[14];
          uint8_t white3  = bytes[15];
          uint8_t red4 = bytes[16];
          uint8_t green4 = bytes[17];
          uint8_t blue4  = bytes[18];
          uint8_t white4  = bytes[19];
          uint8_t red5 = bytes[20];
          uint8_t green5 = bytes[21];
          uint8_t blue5  = bytes[22];
          uint8_t white5  = bytes[23];
        red0 = ( red0+(white0/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red0+(white0/3) );
        green0 = ( green0+(white0/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green0+(white0/3) );
        blue0 = ( blue0+(white0/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue0+(white0/3) );
        xmas_set_color(0,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red0>>4),(green0>>4),(blue0>>4)),XMAS_PIN);
        red1 = ( red1+(white1/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red1+(white1/3) );
        green1 = ( green1+(white1/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green1+(white1/3) );
        blue1 = ( blue1+(white1/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue1+(white1/3) );
        xmas_set_color(1,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red1>>4),(green1>>4),(blue1>>4)),XMAS_PIN);
        red2 = ( red2+(white2/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red2+(white2/3) );
        green2 = ( green2+(white2/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green2+(white2/3) );
        blue2 = ( blue2+(white2/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue2+(white2/3) );
        xmas_set_color(2,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red2>>4),(green2>>4),(blue2>>4)),XMAS_PIN);
        red3 = ( red3+(white3/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red3+(white3/3) );
        green3 = ( green0+(white3/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green3+(white3/3) );
        blue3 = ( blue0+(white3/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue3+(white3/3) );
        xmas_set_color(3,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red3>>4),(green3>>4),(blue3>>4)),XMAS_PIN);
        red4 = ( red4+(white4/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red4+(white4/3) );
        green4 = ( green4+(white4/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green4+(white4/3) );
        blue4 = ( blue4+(white4/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue4+(white4/3) );
        xmas_set_color(4,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red4>>4),(green4>>4),(blue4>>4)),XMAS_PIN);
        red5 = ( red5+(white5/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red5+(white5/3) );
        green5 = ( green5+(white5/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green5+(white5/3) );
        blue5 = ( blue5+(white5/3) >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue5+(white5/3) );
        xmas_set_color(5,XMAS_DEFAULT_INTENSITY,XMAS_COLOR((red5>>4),(green5>>4),(blue5>>4)),XMAS_PIN);
    Level UP!
  9. #19
    Dec 2010
    Oceanside, CA
    2,068
    You don't need to do something like "red+i" and have rgb variables for each group, simply re-use the red, green, blue variables. Since you're using them in another function which writes out the bits before using the variables again you don't have to keep all groups' variables around.
    Something like this loop:
    Code:
      red = ( red >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : red );
      green = ( green >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : green );
      blue = ( blue >= (XMAS_CHANNEL_MAX<<4) ? (XMAS_CHANNEL_MAX<<4) : blue );
      xmas_set_color(i,XMAS_DEFAULT_INTENSITY,XMAS_COLOR ((red>>4),(green>>4),(blue>>4)),XMAS_PIN);
    Also, I was using 4 channels, not 3 since my sequencing was already done as RGB+W by the time I wrote the code. Since I don't see you using a white variable for the 4th channel, you likely only need to read in 3 bytes of renard data per "group". That's why in my example above I took out the white value mixing.
  10. #20
    Sep 2010
    Clear Lake, TX
    211
    I used RGB+W in the code, just forgot to put it in the example loop. Thanks for the feed back, I'm going to implement that code. Going this route will allow me to use any number of groups and group counts provided they equal the total pixel count without having to code for each channel.
    Level UP!
