Page 64 of 74 FirstFirst ... 14546263646566 ... LastLast
Results 631 to 640 of 732
Thread: DIGWDF Store Announcement
  1. #631
    9,237
    Default Re: DIGWDF Store Announcement
    More stock on its way... will have more ESP Snap-In kits in the store next week....
    http://digwdf.com/store/
  2. #632
    New Jersey, USA
    499
    Awesome for all the reasons that it is. One suggestion if I may, is to come up with a rubbery, foam block that's the same height as the header, so ensure the ESP01 module doesn't get physically stressed if it's banged hard or wires in the controller box end up pushing on it when the lid is closed. I broke one that way which is where I got this from.
  3. #633
    Columbus, OH
    4,306
    An excellent idea.
    Have you tired something, just to make sure it doesn't interfere with the antenna function?
    Yes, I know the antenna is physically on top, but, you never know....
    Quote Originally Posted by frederic View Post
  4. #634
    9,237
    Yes, any time you put ANYTHING next to an antenna, rubber, plastic, paper, whatever, it changes the characteristics of the antenna.
    What you CAN do is solder the ESP module directly to the board and let the pins stick out the bottom. Then you still have access to the pins from below to reprogram the module if the need arises, and they don't hamper plugging it into an XBee header. I haven't done a lot of testing with this method yet, but I suspect its close proximity to the lower PCB may have some effect....
  5. #635
    May 2009
    Murrieta Ca
    392
    This may be a dumb question, but is there a reason you could not make the ESP board on the top of the xbee snap in? That way it would only be one board and you would not need a connector at all.
    I'm sure there is a reason you did not do that, but I thought I would ask anyway.
    tweist
    736 Channels
    65+ Wireless Ren controllers
    [COLOR="#0000FF"](2013) 25+ houses[/COLOR]
    (2012) 20 houses total
    (2011) 13 houses total
    2012 video
    [url]https://www.youtube.com/watch?v=_KVM_EPKYMM[/url]
  6. #636
    9,237
    Quote Originally Posted by tweist View Post
    Yep, the existing XBee Snap-in stock level!
  7. #637
    Malden MA
    988
    Sure, you could, but then you get to solder QFN32 packaged chips. Also, it's a lot easier to get assembled modules with the ESP8266 on it from eBay than to get the chips...
    /mike
  8. #638
    May 2009
    Murrieta Ca
    392
    That makes sense. Thanks
    tweist
    736 Channels
    2012 video
  9. #639
    9,237
    ...a limited number of ESP Snap-In and Flashamater kits are in the store.... more on the way after the Chinese New Year shutdown ends....
    We had no idea that this product would jump off the shelves like it has. Fantabulous! What a great way to put those Xbee-controlled units into DMX or high-speed Renard use by putting them on a wi-fi network...
  10. Likes CJHacker, Jrd liked this post
  11. #640
    9,237
    Default Re: DIGWDF Store Happenings
    We also have complete Wireless Combo Kits -- everything you need to make four controllers Wi-Fi!
    Includes all of the following:
    ** USB->TTL adapter and connect cable (to connect to the Flashamater)
    ** Flashamater kit (for programming the receiver modules)
    ** 4 ESP Snap-In Kits (the wireless adapters)
    ** 4 ESP8266 Modules (the receiver modules)
    ** 3 XBee Snap-In Kits (to interface 3 of the wireless receivers to your controllers)
    ** HeadBlinker Kit (our battery-powered wearable controller!)
    http://digwdf.com/store/product.php?id_product=200
    ... and we recently added more PX-1 and LSD adapters for the unbelievably powerful RENZILLA!!!
    OHHHHhhhhh...... magic!!!
