Check out these 12v strobes!
Check out these cool super bright 12v strobe strings!
The PCB inside each tube has 6 super bright LEDs on both sides of the PCB for a 360 degree flash. There are 10 strobes per string and can be daisychained up to 10 strings for a total of 100 strobes. They are sealed to be waterproof. They can be either controlled off a DC controller or could be connected to a pixel controller via an assembled WS2811 DC-SSR boards.
These strings area available right now through our winter pre-sale and are available as individual strings or a three pack along with an assembled pixel DC-SSR. The pixel DC-SSR has three outputs so you connect each string to an output. You can drive up to 30 strings (300 strobe tubes!) off a single DC-SSR!
Like most other strobes they take a little time to randomize. We recommend ramping up the voltage slowly and apply full power when you want them to flash in your sequence.
www.diyledexpress.com
Re: Check out these 12v strobes!
Those are cool! I see on the website it shows an RGB version, but there’s an * by RGB. Can you elaborate? Any videos of the RGB version? Thanks!
Here is a video of the RGB Strobe Strings. The strobe tubes are not individually addressable nor does each individual tube change colors. Each strobe tube is one color.
Cool! Thanks for the video.
- You may not post replies
- You may not edit your posts
Forum Rules
