Results 1 to 10 of 14
Thread: Wrapping Arches
    Default Wrapping Arches
    Need some ideas on wrapping 100ct minis around 3/4 gray conduit. The light spacing on the minis causes the lights to be perfectly 180 from each other. I would end up with 2 rows of 50 lights. I've tried different wrapping methods to get it more random, but nothing looks good. Have others had this problem? Solutions?
    Default Re: Wrapping Arches
    Try folding the string in half or thirds before wrapping.
    Oct 2008
    San Jose, CA
    7,783
    Quote Originally Posted by Virtus View Post
    Exactly right - find the midway point - offset if necessary and wrap from the middle - this has the added benefit of requiring half as much turning and getting the job done twice as fast!
    Brian
    Halloween in San Jose! - FB
    That was simple. Thanks!
    Vancouver B.C Canada
    1,309
    I seen this vid and his method of wraping short sections seems like it would make any ez fix if one needed to replace a burned out or problem strings etc
    http://vimeo.com/27515554
    Dec 2008
    3,364
    and as someone else pointed out in another thread... If one of the 50ct sections goes out, it won't be as noticable.
    www.Kentucky-Christmas.com
    Jan 2008
    Fountain Valley, CA (Orange County, So. Cal)
    1,746
    Another approach would be to wind/unwind the strings a little. For example, to shorten the spacing between bulbs wind the wires a few more times, or unwind them a few times to lengthen it.
    Depending on how much you want to change it, you could also try wrapping loosely vs. tightly - that might be just enough to stagger them.
    don
    Click for display details >>
    web site: http://www.eShepherdsOfLight.com or http://www.facebook.com/eShepherdsOfLight
    technical articles: http://downloads.eshepherdsoflight.com
    Dec 2010
    oklahoma
    675
    Default
    What if you ate using 50 count led strings, does the folding in half method still work. Does anyone know where to get 100 count led strings? Every store I go to only has 50 count or the o asional 60 count led string.
    not so new but still learning!
    May 2009
    Murrieta Ca
    341
    Quote Originally Posted by corytcline View Post
    Try CDI. They have 70 and 100 count.
    tweist
    2012 video
    https://www.youtube.com/watch?v=_KVM_EPKYMM
    576 Channels
    44 Wireless Ren controllers
    (2012) 20 houses
    (2011) 13 houses total
    Dec 2010
    oklahoma
    675
    Default
