Thread: Vixen 2.x SetupDialog help needed
    Nova Scotia, Canada
    1,533
    Default Vixen 2.x SetupDialog help needed
    Hey Folks
    I want to take 2 Buttons in my SetupDialog form
    Button1;
    Code:
    private void button1_Click(object sender, EventArgs e)
             SerialSetupDialog dialog = new SerialSetupDialog(this.m_selectedPort);
             if (dialog.ShowDialog() == DialogResult.OK)
                 this.m_portAddress = null;
                 this.m_selectedPort = dialog.SelectedPort;
    Button2;
    Code:
    private void button2_Click(object sender, EventArgs e)
             ParallelSetupDialog dialog = new ParallelSetupDialog(this.m_portAddress);
                 this.m_selectedPort = null;
                 this.m_portAddress = dialog.PortAddress;
    Now how would I identify which button was selected and properly return the HardwareMap?
    Code:
    //for Button1
            public HardwareMap[] HardwareMap
                get
                    return new HardwareMap[] { new HardwareMap("Serial", int.Parse(this.m_selectedPort.PortName.Substring(3))) };
    //for Button2
                get
                    return new HardwareMap[] { new HardwareMap("Parallel", this.m_portBase, "X") };
    //combined?
             if (this.m_portBase =null)
             get
             else if (this.m_selectedPort = null)
             get
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Chat link
    Christmas Wiki link
    Feb 2008
    Warminster, PA
    1,298
    Default Re: Vixen 2.x SetupDialog help needed
    Since you are doing an either or situation what I would do is in your setup dialog also have a bool member such as bool m_serialSelected. In each of your buttons you would set that accordingly. The you would also set up a property:
    public CheckIfSerialPort
    get {return m_serialSelected}
    Then in your main program you would have a global bool _serialSelected. In the Setup() routine you can set this member using your property(_serialSelected = CheckIfSerialPort)
    You could then set up an if_then_else statement using that to return the desired HardwareMap.
    Nova Scotia, Canada
    1,533
    Thanks Chris
    I'll give it a try.. This is one of the snags I have with my miniRDS plugin, I need to give it the choice between LPT and Com
    Once I get it to post properly in the Vixen Attach Plugin window, I need to pass either the m_selectedPort or the m_portBase over to the miniRDS.cs module
    Cheers!
    Steve
    My weather today
    Chat link
    Christmas Wiki link
