I'm not sure it would be that much more expensive, it might even be cheaper, lets see.
24 strings of LEDs @ $12 a string and a SS24 controller (about $50) for a total of $338 for every arch. (ouch!)
I've seen postings for arches made with a single 4 meter (120 node) pixel flex strip in tubing. If you used the setup I have, the flex strip is about $75 (for 1 with shipping from China), an SSC controller, EtherDongle and Active Hub together are under $200 and each additional arch would only require a flex strip and SSC which would be under a $100 total for up to 10 additional arches. So using this logic 11 LED string arches would cost about $3700 while 11 flex strip arches would be under $1275. Using a 128 node string instead of the flex strip would only add about $25 per arch.
I think if you ran the numbers with the E681 and matching pixels or flex strips the numbers would be similar.
These numbers are a very rough guesstimate and your mileage may differ.
