Results 1 to 10 of 20
Thread: How To Build 8 Channel Light Arches
    Dec 2008
    3,364
    Default How To Build 8 Channel Light Arches
    Eventhough I used the Arch method, I have received many questions about my arches. I actually call them leapers. If you are considering adding arches to your display, check these out. Its not the only good way, but they certainly work for me. I couldn't be happier with how they turned out. After 3 seasons of setup and take down, I still love them and am very satisfied. There are also some pictures of the mini lathe I built to wrap the Arch sections.
    Kentucky Christmas Light Arches
    PM me or use my Guestbook if you have questions.
    www.Kentucky-Christmas.com
    Nov 2009
    Morrisburg, On, Canada
    319
    Default Re: How To Build 8 Channel Light Arches
    The next phase is to use a sewing machine peddle to control the rotation speed of your "lathe".
    I also see you're taking advantage of "low paid" labourers?
    Robbinsville, NJ
    842
    I used your method this year for 2 arches. My only suggestion to anyone using them is to be careful when dis-assembling them. As you try to disconnect the sections, the tie-wrap can slip off the edge. It's a PITA to put back on and if you are not careful the wires can un-ravel.
    Michael
    New for 2013: Add'l Ren4Floods (3); add'l DMX TX/RX; add'l E681; GECE MegaTree; start conversion from RGB incans to LED. Learning how to WELD! Building my first wireframe; Making a nativity cutout scene; PIXELS!!!
    FACEBOOK: https://www.facebook.com/GothambeatProductions?fref=ts
    Gotham Beat Productions LLC
    Dec 2010
    Central Mississippi
    233
    hot glue ziptie to pipe.
    2007-2010 Used a dumb blinky machine.
    2011 - overwhelmed with CLAP and did not make it in time for blinky flashy.
    2012 - First full show. 130+ channels
    5@Ren24SS, 2@Ren8SS, 1@Ren16SS, 1@Ren48LSD, and 17k lights
    2013 planned - 2@E681.5 for GECE roofline, 2@E682 for WS2811 megatree conversion & addt'l 3@Ren24SS for 34k lights
    Spencer Iowa
    1,084
    One thing I did when I built my poles(vertical arches) since I was turning the pipe by hand.
    Was to fold the string of 100 in half into two strands of 50.
    This way you are wrapping two strands at once that are only half as long.
    The other major benefit is that by having a double strand you have some built in insurance
    that if half the strand goes out that section may be less bright, but it will not be dark.
    Joel
    If I no longer count channels... but instead say I have over 12 universes... Is that too many
    Moved to more appropriate thread...
    8,019
    Quote Originally Posted by jrock64 View Post
    Joel
    Joel, you are without a doubt one of the most clever guys I've ever met. Great tip!
    dirknerkle
    Dec 2008
    3,364
    Quote Originally Posted by LightUp View Post
    Just didn't give all the details, but I actually ended up switching to a Router Speed Control that I had laying around and used a foot switch extension cord. I didn't get to my vertical poles this year, but they will be built the same way (larger PVC). Before I do most of them, I'm going to change to a permanent motor setup using a Grill Rotisserie motor.
    The girl is 5 now, but whe was only 3 in this picture. Of course, I loved having her there, but I remember she knocked the stool over on the lights and broke a brand new strand. Also, before the session was over she fell of the stool and hit her head on the Bench. No stiches, but certainly did not make the project easier? The free Labor always cost in the longrun somewhere. It really has been great with the kids. Since its my hobby, I don't force them to help. When they do, I know they are there because they want to be and it makes it more fun. This goes for the 16,13,7 and the 5 year old.
    Dec 2008
    3,364
    Thanks Joel. Although I struggled with it, The WIKI method actual show attached one end and the the other end at the 18" mark. So essentially wrapping as a "V" I really like your idea. Then I could be a little lazy on those cold days and not worry when a Half a channel is out May use that when I finish my Vertical Poles this year.
    You have to love this place. I think I'm doing Noobs a favor by posting the details and pictures and I end up getting good advice. It would appear I'm not just paying it forward, byt I'm still getting paid.
    Joel
    Xenia, Ohio
    660
    Well us "noobs" really appreciate the help. I was going to make the Carney Arches but like this better. My lights are from Sams and are 200 strand 55 ft. leds. I am going to use 1 " gray PVC in four foot lengths with 2 foot segments. The arch will be sixteen feet long and should be 12 foot or so wide as I want to leave them relatvely flat only 3-4 foot high. I like the idea that these can be used as part of my twelve foot vertical and double as spares for the arches.
    First year up and running! Over 35,000 lights and 410 Total Channels of Blinky Flashy - 275 Channels Renard and 135 Channels of E1.31. All wireless. Show is just over 30 minute with 11 songs so far. Whew - What a first year!!
    www.xenialights.com
