Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: DMX, Renard, sACN Tester
    WI
    2,612
    Default Re: DMX, Renard, sACN Tester
    Update: I've started porting the W5100 code to the W5200 so I can use it for this project. Also I think I'm going to be creating two versions of this tester, a very feature rich version that is SMT for myself, and a more basic through-hole version for the community.
    Because I do stage work there are a number of features I would like to see that would add expense and complexity to the project. So my current plan is to make the more complex version first and the make a "lite" version after that. The lite version should just amount to removing some hardware, swapping SMT for DIP, and removing some code objects.
    Nov 2010
    Placerville, CA
    2,199
    Any ideas on a ballpark BOM cost?
    [I][SIZE=2]"Beam me up Scotty, there are only limited pockets of intelligent life on this planet!!"[/SIZE][/I]
    WI
    2,612
    Quote Originally Posted by CaptKirk View Post
    No clue for either at this point, its still early. Here is what I'm thinking right now:
    Both versions will use W5200 and an LCD display ($20) with switches to navigate menus.
    The "lite/community" version will use the new WizNet module with the W5200 that's $20, there won't be any DMX isolation, power will likely be via 9V battery and wall-wart, it may have both a DMX in and out, and RJ45s for DMX. The problem with DMX In and Out is PCB mount RJ45s are typically female only, I might suggest people solder a male whip for one of them to keep In and Out straight. Also I'm hoping to source an inexpensive handheld case for this one to keep it small.
    The "pro" version will be similar but I might not use the wiznet module, this one will have isolation, it will be AC powered with rechargeable batteries, a DMX cable check feature will be onboard, and 5 pin xlrs for DMX. This one will likely have a watertight case with latching cover, similar to a small Pelican case.
    Delaware, OH
    4,520
    Nice !
    Can't wait to see it.
    WI
    2,612
    Me too. ;)
    Nov 2010
    Placerville, CA
    2,199
    Same here especially since I will be running a mixed environment of all three protocols this year.
    Sep 2008
    Baulkham Hills, NSW
    2,609
    Default
    Ben,
    Did you take this further?
    Sent from my GT-I9100 using Tapatalk 2
    [B][I]Matt[/I][/B]
    WI
    2,612
    Ben,
    Sure but it isn't finished yet. I've been focused on the highly featured "pro" version for myself, only after that was done was I going to do a community version. Unfortunately I need to back-burner it until mid-July.
