Results 11 to 20 of 28
Thread: DMX, Renard, sACN Tester
    Jun 2009
    Ottawa, Ontario, Canada
    2,845
    Default Re: DMX, Renard, sACN Tester
    Devices typically use a "program" header/jumper/switch.
    I suspect that is what we're talking about here.
    Standard Disclaimers apply:
    WI
    2,611
    So in my code if I drop into a "device programming" mode and continuously send the string I should be good?
    Jun 2009
    2,845
    That is my understanding. Here's a pic of what I had been working on, but haven't followed through with.
    As you can see... I didn't design for the enclosure, and even neglected to include mounting holes. (silly designer)
    Sep 2008
    Baulkham Hills, NSW
    2,608
    Most units use the Link pack / switch option. I prefer the push button switch cause I am worried about losing link pack in the garden when doing changes on the fly.
    Prior to RDM, I believe JEC came up with a sequence / method that will set the Controller into address setting mode. (Not sure if this has been published.) http://response-box.com/rgblights/2007program.shtml
    [B][I]Matt[/I][/B]
    Avon Lake, OH
    479
    Sounds like an interesting project. I would be interested in one.
    Erik
    Give back to the site that has given so much, become a [URL="http://doityourselfchristmas.com/forums/payments.php"]supporting member[/URL].
    WI
    2,611
    First design challenge: I would like to have one connector for Tx and another for Rx, and they need to be locked to that function. On a commercial DMX tester these functions are enforced by connector gender, the problem is an RJ45 has no polarity. Short of color, or using XLRs instead of RJ45s, I can't think of a way to make sure that the connectors don't get mixed up. Opinions?
    Sep 2008
    Baulkham Hills, NSW
    2,608
    Why? just read the incoming port first before letting the user set the unit to TX. If you can read DMX or Renard, disable the TX function and issue an error message.
    [B][I]Matt[/I][/B]
    WI
    2,611
    Two reasons. First I want a cable testing feature. Second I can do some interesting "man in the middle" diagnostics for troubleshooting.
    Sep 2008
    Baulkham Hills, NSW
    2,608
    So you are now assuming I meant only one Connector. use two connectors ansd let the use decide which one is TX and Which one is RX. Before you enable TX, Enable RX and make sure the cannel is quiet.
    [B][I]Matt[/I][/B]
    WI
    2,611
    Actually I wasn't assuming that, what I mean is that from a hardware perspective what you are suggesting won't be an option. With that said this might not be a a set of features this community is interested in.
